Question about Motorola Mobility Bluetooth Hands-Free Speaker T305 Wireless Headset
How do I sync my motorola bluetooth 1716d with my evo phone?
I had my blue tooth syncd with my old phone now I would like to sync with my new phone. What do I do? I have forgotten how I did it originally.
I465 bt passkey
You should not need pass key.Just send to new number
it will ask if you will accept click yes, that should be it.But you
probably need to search with new phone Blue tooth while old
phone on and on Blue tooth.Once it finds it synch with it.
LUCK
May 14, 2014 | Motorola Clutch Cell Phones
I am trying to disconnect my bluetooth from my old cell phone and reconnect it to my new cellphone
Unable to connect my new iphone to the bluetooth in my car.
I've turned off the blue tooth in my old phone but it only turns off the bluetooth in the car. I have tried to then reconnect my new iphone, which is searching and showing that it has located the bluetooth (blue tooth flashing in car, shows on the sceen for a second and then turns off with message 'no service' phone off. If I turn on the old phone, everything comes back on.
Any ideas?
Jan 23, 2011 | Motorola Mobility Bluetooth Hands Free...
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Good luck from Headsets Direct!
Feb 14, 2009 | Plantronics Explorer 330 Headset
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility Bluetooth Hands-Free Speaker T305 Wireless Headset Logo
81 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
