Question about Neff Dishwashers
End light flashing
Dishwasher end light is flashing machine seems to work for a couple of seconds and then stops before filling with water. Have emptied out water, blown through waste pipe , tilted machine still no change. Can you help please?
  • 3 more comments
  • jnevins Jan 02, 2009
    Machine is a S5443X1GB Neff inbuilt dishwasher. There is water pressure, and the inlet filter is clear, it is not flooding as the water drains when the machine is switched on but then stops and end light flashes and nothing more happens. Have blown through waste pipe and tilted machine still nothing.
    Which filter do you mean?
    Did what you said but appears to be something to do with the programme so will get in a repairperson. Thank you
    Master:
  • 416 Answers
It can be bad float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher.
Good Luck
Posted on Jan 02, 2009
    Novelist:
  • 163 Answers
You need to replace the filter of your dishwasher.
  • ronny2051 Jan 02, 2009
    k..
    first check --shut off the hot-water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel; disassemble the valve to reveal the screen; clean debris from the screen; and reassemble. If the screen doesn't appear to be blocked, call a repairperson
    Genius:
  • 1,269 Answers
What is the exact model of your unit? Please check any leak and clog on the filters.
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Dwf50 hotpoint aquarius dishwasher
    hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
    I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
    Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
    Jun 16, 2008 | Hotpoint 24 in. DWF32P Free-standing...
    Indecit dishwasher not circulating water
    Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
    Mar 04, 2008 | Dishwashers
    Whirlpool dishwasher adp550
    f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
    1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
    if water has drained out you may have an water sensor fault or worst case an electronic control board fault
    to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
    Feb 19, 2008 | Dishwashers
    Kenmore dishwasher Lock On light flashing
    holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
    will go back to normal, normall takes more than four seconds to unlock the unit, this is something
    the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
    Dec 29, 2007 | Dishwashers
    Dishwashers Logo
    82 people viewed this question
    Top Neff Dishwashers Experts
    shaun taylor
    Michael Galve
    Michael Galve
    Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
