Question about Maytag Performa PAV2200
Unbalanced washing machine
I just bought a LG tromm wm1812cw and when on the spin cyle i swear it walks across the floor, i have tried to level it but it seems not to help, when i ran an empty load the spin cycle was fine, but as soon as i added some clothes it moved again , how can i fix this? I made the mistake of trying to move the washer machine after having to have started a full load,    I had  dropped  my keys and had no choice,  having done  so it walks when on spin cycle ,  I have yet to take my MAYTAG performa apart,  what will i be looking for ,  My E-mail is volunteerdad@yahoo.com
    Sergeant:
  • 311 Answers
There may be shipping bolts that you have to remove.read your instructions 2 see
Posted on Jan 02, 2009
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
LG Tromm
Place a good level on the top of the machine where it is flat. Check front to back and side to side. Level machine exactly. Now put a load in and when it spins feel the feet for any that are not solid on the floor. Adjust the foot down until the machine stops shaking.
Apr 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Jan 04, 2009 | Washing Machines
LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Jan 02, 2008 | Washing Machines
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
281 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
