Question about Canon Network-Ready Black-and-White Laser Printer/ Copier/ Scanner/ Fax
Canon MF4370dn Network Multifunction Laser Networking setup prob
I need to figure out how to hard reset my new canon machine. I somehow messed up the network setting through my remote UI and now my printer cannot be found on the network. Any help?
I never figured out how to reset the machine but I figured out what I messed up on. I accidentally toggled the MAC address RX Auto to off. This means you must specify the MAC address of the machine you want to access it. This is why my computer could not find the printer. I went into the settings on the machine and changed it to auto and it works great.
Posted on Jan 03, 2009
Hi.. i would like to ask on how to fix error 225 on Canon MF4370DN.thanks!
This error is comon and occurs due to faulty lamp. Change the lamp, reset the system and restart to see results.... Good Luck.
Jan 13, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
Vista says CANON MF4370dn printer always offline? IP addrs issue?
first of all, download updated driver from and install ( before install, remove old drivers and programs)
and if appears again, change your network cable.
Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
Canon MF4370dn 4-in-1: scaner software installation problem
read the manual instruction.and call canon service center and get assistance from tech support.
May 13, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
In Win Vista my new Canon mf4370dn is being reported as offline.
Go to this canon site and install the firmware update. This was happening to me all the time until I installed this firmware update and now I can print to it all the time. I used to have to turn the printer off and back on just to get the printer to wake up.
Jan 13, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Exact same problem as OP
Canon support was able to help me with this issue.
First, scanning with the MF Toolbox is only supported via USB, not across the network (scanning across the network generally does work but you need another application that supports it). Second, you must make sure that you have switched the device into USB scan mode. Press the Scan button on the device. If the display says "Network scanning" press it again until it says USB Scanning. From then on, scanning works beautifully.
Aug 22, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Canon MF4370dn printer network connection problem
I had the same problem. I entered the info manually and it works. You could follow the instructions on how to do it manually in the e-manual (on the CD).
To get the IP, subnet mask, and default gateway: open a command prompt from windows. At the command prompt, type "ipconfig" without the quotes. Write down the IP address, subnet mask, and default gateway.
For the IP, for example, if what you have from the step above is, add 10 (so that you wont have repeated IPs by auto DHCP from the router. I am assuming you have no more than 5 machines on your network.) to the last number to have to enter manually into the printer. Use the same subnet mask and default gateway.
Hope it helps.
Mar 15, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Canon Network-Ready Black-and-White Laser Printer/ Copier/ Scanner/ Fax Logo
2,704 people viewed this question
old marine
old marine
