Question about Metra 80-5511 1995 - 1998 FORD CONTOUR SE Car Audio Radio Wire Harness
I have a 1995 ford contour se 5 speed. the car is running hot. the fan is working and their is no fluids leaking. there is no antifreeze smell when heat is on but heat is blowing cold. even with heat running car still overheats and windows do not fog up when heat is on. is this the thermostat?
  • 32,281 Answers
Yes the thermostat could be faulty, most like stuck in the closed or partially closed position.
Posted on Oct 25, 2012
4 cyl., 5 speed. Why is it leaking somewhere under the frame - not transmission fluid
Smell the fluid. If it smells like gasoline you have a gas leak. If it smells like antifreeze you could have a hose or a anti freeze cooler line leaking. Or could be a water pump leaking and running along the frame under the car. Get a flash light and crawl under neath the vehicle and see where the fluid is coming from.
Dec 26, 2015 | 1997 Jeep Wrangler
Where reclaim port is located & how to remove used fliud from 2000 ford contour se 4 cyl.
The ac fluid(gas ) never gets old as it is a gas . The oil never oxidises as there is no air in the system so it never needs replacing. Most problems with ac units come from leaks and owner interference ( replacing gas that doesn't need replacing) or over filling with the wrong gas or just not understanding how and why it all works.
May 25, 2014 | 2000 Ford Contour
No heat blowing cold air.
Do you smell coolant inside of the vehicle. If so then chances are your heater core is going.
Nov 23, 2013 | 1997 Ford Contour
I have a 1995 ford contour SE 5 speed. it is running hot almost red lining.no fluids are leaking, no antifreeze smell inside, windows do not fog up when heat is on but heat is blowing cold air, fans are...
Could be a thermostat problem, or potentially a blown head gasket.
if you take the oil cap off and check under neath the cap (inside of cap) if there is sludge buildup i would get the gasket checked.
Also try check in the radiator, if it looks like there is gunk or **** in the radiator it may be just enough to block the thermostat sensor. Usually if its a thermostat problem the temperature dial doesnt move.
Firstly would check for head gasket, thermostat and note how fast it heats up, when does it overheat (on idle, driving on highway, driving round town, etc)
Oct 24, 2012 | 1995 Ford Contour
1999 ford expedition. smells like antifreeze in the cab, worse when I turn on air conditioner ?? I saw a leak today at the firewall. I drove it about 5 miles stopped the car and it hasnt leaked...
This is likely the heater core leaking. Once it turns cold you will have foggy windows too.
When the heat is turned off the antifreeze stops flowing through the heater core, once it was all gone the leak would have stopped until the next time you need heat.
Sep 08, 2011 | 1998 Ford Contour
I smell antifreeze,found no leaks,vehicle is not running hot
Its the heater core you smell it on the inside because the fan is blowing it into the vehicle antifreeze is unuswal stuff it forms a mist and becomes air borne even a small leak you will smell with the fan running look for wet spots on the carpet under the core but the mist may be so fine and you wonn;t feel it but this your problem
Nov 13, 2010 | 2003 Ford Expedition
What will make a 1995 ford contour transmission feels like it went into a lower gear and sometimes the rpms will tac up once it catches you will hear a noise like a belt slips then the car will ****...
It seems like your transmission bands are slipping, it may be time for a transmission overhaul or you coiuld be low on fluid. Check your transmission fluid, if it is a pinkish color it is clean, if it is a dark red or black color and if you smell it it, it smells burnt you may have some damage to your transmission.
Jun 03, 2010 | 1995 Ford Contour
Coolant boiling over in 95 ford contour cooliant light on but resevoir is full
First if you coolant is boiling over you may have one on the following problem, bad thermostat-stuck closed. bad water pump bad radiator fan or fan switch or antifreeze leak-bad hose etc. Bad head gasket. Contact if you need more help,thanks for using FIX YA
Mar 03, 2009 | 1995 Ford Contour
Metra 80-5511 1995 - 1998 FORD CONTOUR SE Car Audio Radio Wire Harness Logo
64 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
