Question about Splendide Ariston Stackable Collection Washer
Can't open Ariston Splendide washer door. The cycle is complete but the door is locked. How can I open it?
  • 1294 Answers
SOURCE: Splendide 2000S
Go to: repairclinic.com
Posted on Mar 13, 2008
  • 68 Answers
SOURCE: Splendide 2000 S runs through cycle but water left in unit (hums)
The drain pump is probably clogged. or drain hose is kinked. I have a trouble shooting guide if you are interested.
Coach Tech RV
734 777 6432
Posted on Mar 23, 2009
maintenacemi
  • 95 Answers
SOURCE: door locked
THE CAPACITOR IS FAULTY that discharges so door can be opened safely it should be at the rear of mc inside attached to the side of mc make sure u get correct microfarfad replacement
Posted on Jan 13, 2010
  • 19 Answers
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
Posted on Oct 24, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a splendide WD2000S
Hi
Try and reset the power to the washer and check after 10 minutes if washer is displaying any error code on the display. If no error codes then check the wiring harness by opening the top panel of the washer. Also verify there is water entering the Hot and Cold Valves, use a multimeter to check the continuity of the inlet valves. Then check the Door Switch for proper operation, the door must be locked:
1. Begin with the machine OFF. Using the Program Selector, select any cycle.
2. Next, press the ON/OFF button "in" to the ON position. You'll hear the door lock engage.
3. Now, unplug the washer-dryer from the wall outlet and check for continuity at the following points.
NOTE: Because the washer-dryer will automatically unlock, the reading must be taken within 1-minute after the washer-dryer is unplugged.
Test Points Reading
Unlocked Door-- 1 to 2 -- INFINITY (OL)
Locked Door -- 1 to 2 -- 0 ohms
Hope this helps... Please post back if you need more information.
Daniel
Posted on Feb 01, 2011
Washer/dryer has completed two cycles and the door won't open
The door lock mechanism is stuck. You will need to get access to the back of the machine in order to undo the screws holding the top of the machine on. Make sure the machine is unplugged from the pains supply, there are wires attached to the switch and they may be live. Remove the top of the machine and reach down inside to where lock is (near door handle on front), push on the back of the lock/switch and it should release. If the problem re-occurs then the lock/switch will need to be replaced.
May 03, 2016 | Hotpoint Ariston Aquarius WD420 Front Load...
Where to finde front door handle
This is the information taken from the Splendide website. Hope it helps.
Westland Sales - Splendide Service Headquarters in Clackamas, OR Telephone:
Direct Fax:
E-mail:
Hours: 1-800-356-0766 #5 (503-656-2280)
503-722-9202
*To help us serve you better, please have the Model & Serial Number of your machine ready when you call. The Serial Number is located on the inside door opening of your machine.
Jul 26, 2014 | Ariston Technologies AWD 121
Cycles won't advance
the module board is bad and needs replacing. it controls all the functions. it's at the bottom right rear corner.
Feb 28, 2014 | Splendide 2100XC
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
Constant clicking of door lock
Suggestion: Try a little WD40 spray on the door, not on the machine. Close and open 2 or 3 times while plug is off the wall mains.
Click if helped.
Apr 14, 2013 | Ariston Technologies Ariston AWD12 Front...
Splendid 2000s washer dryer door won't lock
Possible that the door lock is jammed and needs to be replaced.
please check this link;
Replacing door lock
Jun 06, 2012 | Splendide Washing Machines
Door lock not engaging on our spledide XC 2100
I'm Sorry to post a complete "Gerry Rig" solution to the problem: I inserted a plastic clip in the door lock to fool the machine that the door was locked; removed the clip then secured the door with a tension rod. It ran its full cycle without a leak. I think the plastic door mechanics was inadequately engineered. Our Machine is less than 6 months old?- Im on the road & have to make things work on the fly. Warning my next fix might include Duct Tape Good Luck Everyone Kevin_ByDesign
Jul 20, 2010 | Splendide 2100XC
Coach Tech RV
734 777 6432
Mar 23, 2009 | Splendide 2000S Vented Washer/Dryer
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Splendide Ariston Stackable Collection Washer Logo
135 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
