Question about Dell Dimension 4600 PC Desktop
Factory Reset I need to do a factory reset on a 5 year old dell dimension 4600 desktop. Any help would be greatly appreciated. Mike
  • magoo_andy May 11, 2010
    do you need a motherboard reset or hard drive.
  • Dan rogers
    Dan rogers May 11, 2010
    do you mean start over with a fresh install?
  • 59 Answers
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The
Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received
Posted on Jan 02, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
My Dell Dimension 4600 won't connect to the internet and has a solid orange internet light, help?
go into internet options and connections and tell it to never dial a connection see if that helps
Jul 12, 2012 | Dell Dimension 4600 PC Desktop
I had to do a factory reset on my dell dimension 4600 and i managed to get windows xp working but i cant get the internet to work. i cant get it to find my bt home hub it is wired with an ethernet cable...
Use whatever computer you are using to reach FixYa.com to go to Dell.com, and click support. If the 2 computers are in different locations, write down the Service Tax number off the back of the dell, and take it with you. Also take a thumb drive with you that has at least 1 GB of free space. On the Dell Support page, type in the service tag number, and hit enter. Tell it you want drivers & downloads Tell it what version of windows you are using From the files selected, download all of them. Put them all on your thumb drive. Take the thumb drive to your Dell. Insert the thumb drive. Install the drivers one by one until one of them makes your network card work.
Apr 29, 2011 | Dell Dimension 4600 PC Desktop
How do I restart a Dell Dimension 4600 PC Desktop
Hello gabeymybabey,
If the computer is using Windows XP, do the following to restart the system:
•Click the Start button
•Click Turn Off Computer.
•Cick Restart
The computer will restart after the shutdown process finishes.
Also, here's is a link to the Dell 4600 Series user guide:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 31, 2010 | Dell Dimension 4600 PC Desktop
4600 Sluggish Boot Up
sounds to me like a failing psu, you may need to test it with a psu tester if you have one available, if not any local pc repair shop should have one
Oct 31, 2009 | Dell Dimension 4600 PC Desktop
Dimension 4600 won't reset to factory settings
These model dells came with a recovery cd rather than a partition. You will need to call dell and have them send you a recovery cd and then use that disc to restore your computer to factory defaults.
May 27, 2009 | Dell Dimension 4600 PC Desktop
First, if you have any data on the machine you want, I'd back it up to a USB flash/thumb drive.
Then, assuming you purchased the machine new, you should have the maroon/silver "Recovery Disk". Pop that in the CD, and restart the machine. Press F12 to select BOOT OPTIONS. Select CD Hit Enter. This should start the Dell Recovery process. If you do not have the Rec. CD, contact Dell. They should be able to provide you the org. software - for a small fee of course.
gurutim
Mar 21, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
887 people viewed this question
Alun Cox
