Question about Hayward 1.5 Hp Northstar High Performance Pump
Can't get my Hayward Northstar SmartMax pump to pull water, it only makes a noise and does not pump water
Makes just a spinning noise. I pulled the pump and everything seems to be ok and turns.
    Problem Solver:
  • 20 Answers
Have you looked at the vanes in the impeller? if they are significantly clogged nothing will pump or flow.
Posted on Nov 21, 2013
2 Suggested Answers
  • 990 Answers
SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
My Hayward Northstar 1.5 HP pump is pumping water into the pool, but not at full flow rate. This started happening after I cleaned out the filter basket that was plugging off the pump. The cap seems to...
you may have some debris in the impeller. you'll have to separate the wet end from the motor and access the impeller to see if it is partially plugged with debris. Northstar pumps have a closed face impeller that can trap debris at the opening and slow flow dramatically.
Aug 01, 2011 | Hayward 1.5 Hp Northstar High Performance...
I'm trying to remove the motor from the back of my Hayward pump (Northstar). I've loosened the large, round locking housing that secures the motor to the pump. It appears the motor should now just slide...
You didnt mention removing the impeller before trying to "slide it out" Remove the impeller and diffuser first before trying to seperate the two pieces. Lock onto the rear shaft with a 7/16th" wrench while rotating the impeller counter clockwise until remoed. Now you can seperate the two halves.
Apr 21, 2011 | Hayward 1.5 Hp Northstar High Performance...
Pump hums but is not pumping the water.
you either have a problem with a suction side air leak, a bad start capacitor, or bad bearings.
Start with trying to prime it by adding water to the hair/lint pot. If it doesn't move any water and it acts like the motor is not turning, it's most likely a start capacitor. The pump would have been making alot of noise before the bearing would have been bad enough to seize.
Aug 15, 2010 | Hayward 1.5 Hp Northstar High Performance...
My Hayward pool pump was humming, but I got it running. Now it is not pulling water into the filter. Does anyone know what the problem could be?
WELCOME TO THE DREADED NORTHSTAR..THEY FAILED TO PUT A LOCKING SCREW ON THE IMPELLERS ON THESE WITH A MOTOR THAT CAN RUN IN REVERSE ON A WHIM . SO WHAT ITS DONE IS MUCKED UP THE THREADS ON THE IMPELLER.. YOU WILL FIND THAT THIS IS THE HARDEST PUMP TO WORK ON ! PARTS $$$ CRAZY .. I SEE A NEW PUMP IN YOUR FUTURE ,, A STA-RITE DURA GLASS !....; WHEN GETTING A NEW PUMP TELL THE THE HP AND SF SERVICE FACTOR OF THE HAYWARD YOU HAVE SO YOU GET THE RIGHT SIZE PUMP FOR YOUR NEEDS ..GOOD LUCK AND VOTE FOR ME...JAY
Jun 13, 2010 | Hayward Northstar Pool Pump 2 Hp Sp4020ns
My hayward northstar pump makes a loud noise when
Sep 29, 2009 | Hayward 1.5 Hp Northstar High Performance...
5yr. old Northstar 2hp, humms at start up and then pops breaker.
capacitor maybe hard to tell must be check but the cheaper option will the capacitor check for loose wires
Sep 01, 2009 | Hayward Northstar Dual Speed Max Rate 2 Hp...
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 1.5 Hp Northstar High Performance Pump Logo
99 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
