Question about Dell Vostro 200 PC Desktop
Can't conect to internet with my dsl modem
  • sgfd Oct 25, 2012
    When did it stop connecting and what were you doing before it happened? How are you connected to the modem?
  • joecoolvette
    joecoolvette Oct 25, 2012
    Was working then quit? Modem is bad. If it was on motherboard, or a separate adapter card; install a Ethernet adapter card in an open available white PCI slot. 1)http://support.dell.com/support/edocs/sy... (Number 22 and 23)http://www.tigerdirect.com/applications/...
    Sergeant:
  • 247 Answers
Check to see if you already have a PCI card installed, its common to buy one from a store or a private person and the on-board card does not work and a PCI card installed, check the back of the PC to see if there is a 2nd NIC port avail. and before you go spending money on another PCI card check your device manager to ensure your are not having driver issues. in closing, check your network cables as well and make sure they are all securly plugged in on both ends.
Posted on Dec 27, 2013
Internet signal keeps dropping
There's a lot of possiblities here.If you have a DSL/dialtone lineshare,listen for noise on the line(humming,crackling static,dropped calls).If you have a dry loop(DSL only),connect a phone in place of the modem and see if it has an "intercept" message(like "you have tried to call a number out of your service area" or something like that).If it does,you can use a phone to check the line when the DSL drops(don'touforget to put an inline filter on it).If the DSL light doesn't go out when the Internet light does,it is NOT a problem with the physical line.This would be an issue with the modem or the equipment at the serving end.( I am a DSL tech,and spend lots of wasted time diagnosing and trying to fix problems that are beyond my reach(central office server issue) or that I didn't need a dispatch for(it is cheaper to send a new modem than to send a tech).
Jun 02, 2012 | D-Link DSL-2640R Wireless G ADSL2 Modem...
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
I just got att dsl service. I have four green lights on the modem and wireless is working. I can access wireless on my phone and laptop in the house. When I open IE, all I get is "cannot display...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
Jun 03, 2011 | AT&T High Speed DSL Modem
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
I can connect to the internet with my router, however periodically it will lose conection. This happens over and over again. Usually around 5-6 times during the lenghth of an average movie. I have tried...
While it's true interference could be causing the issue, there are several other possibilities.
More than likely it's not your router that's losing connection, but your actual internet connection itself. If you're using a cable or DSL service for you internet connection they may be temporarily dropping the connection. It's common in large communities, apartment complexes, etc for connections to "blink" in response to increased bandwidth loads. It's also possible that if your connection is DSL based that your telephone line is connected to a bad circuit.
I would start by watching your Cable or DSL modem and see if you notice the Internet light change status while your watching a movie (when it drops connection). If you do you, should be able to call your provider to come out for a service call.
May 03, 2011 | Belkin Wireless Play Max Router (F7D4301)
No conection..
when you are upgraded to windows 7 means ,please contac your internet service provider ,there might chance ,like your ports,might be blocked ,get the help from your internet service provider or esle if you have any firewall or antivirus software means disable it and try to access the internet.
Nov 11, 2009 | Computers & Internet
Wont conect to internet
hi. sir.
go to the internet option>
connection>
setup> choose which type u need to do>
see whether the modem is enabled first. thank u. sir
Sep 03, 2008 | Dell Inspiron 1100 Notebook
Can get to the 192.168.0.1 page but can not connect to the internet, i keep getting either low conectivity. or cabel in plugged. i have the di-524 ops is xp
Sounds like your DSL/Cable modem is not talking properly to your new wireless router. Depending on your modem, my first guess and thing to check is that your DSL/Cable modem is in bridge mode to connect to your new wireless router.
Apr 05, 2008 | Computers & Internet
Dell Vostro 200 PC Desktop Logo
80 people viewed this question
Alun Cox
