Question about RCA L32W11 32 in. HD-Ready LCD Television
Have rcl3210 and the picture flashes in and out, unplug for 10min plug back in and sometimes seems to fix prob. other times screen just keeps flashing
    Problem Solver:
  • 12 Answers
I have the same problem and from researching the issue it seems to be the power board in the tv. Megmeet (MP116) RVE 1.6 is the power board info.
Posted on Aug 21, 2014
Diagram for runtka419wjqz
my sharp aquos also have the same problem,
i am also finding how to fix it
model is lc32d30
when i press the power on button,
the tv on and flash for 3 times with picture and sound,
then it go off, and switched to standby,
i unplug the signal line with 9 connecting points between mainboard and power board ) and power on,
the screen has no responds but the loudspeaker keeping run and the green power glow normally for a long time,
and i plug the line back to the socket again (hot plug ),
the symtom go back again,
it may be cause the protect circuit,
but i don't know how to fix it
Aug 21, 2011 | Sharp Televison & Video
I am a PS3 owner and have had the device repiaired by Sony previously. Once I got it back it was all ok; now its happening again (2 months out of warranty now!!) While in gameplay the tv screen would...
I want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step videos or the paper guide.
The best thing is to get and keep your repair guide for life so if something goes wrong in the future you can just review your guide and fix it.
Click here to download repair guide
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
Jun 07, 2017 | HP DeskJet 5150 InkJet Printer
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Dec 11, 2007 | Toshiba 43A61 43" Rear Projection...
RCA L32W11 32 in. HD-Ready LCD Television Logo
160 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
