Question about Promethean Board Lamp for PROMETHEAN PRM25 Projector
Flickering The on screen image flickers. Changing the lamp did not correct the problem.
Did you check your cable? if the connection is bad the image will flicker in and out.
Posted on Oct 25, 2012
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
Flickering screen
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 05, 2009 | Acer 4220-2346 Notebook
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Laptop screen flickering in hp laptop. had it for 1 year. screen stays on but flickers black very quickly
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 05, 2009 | HP Computers & Internet
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
My screen flickers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 08, 2009 | Sony VAIO VGN-C140G/B Notebook
The left side of my Dell inspiron screen is darker than the right. Changing the brightness only changes the brightness proportionately. any suggestions
  • Picture flickering with dim display.
Apr 29, 2009 | Dell Inspiron 1525 Laptop
"Flickering" screen
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 15, 2009 | Toshiba Satellite A105 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Mar 13, 2009 | Gateway MX7118 Notebook
The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
Oct 04, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Promethean Board Lamp for PROMETHEAN PRM25 Projector Logo
501 people viewed this question
Top Promethean Board Office Equipment & Supplies Experts
FireballXL55
Gramonion
Gramonion
Level 1 Expert
Are you a Promethean Board Office Equipment and Supply Expert? Answer questions, earn points and help others
