Question about GE Profile JB968SHSS Electric Kitchen Range
GE range model JB578GP oven not heating up to right temp, approximately 100 deg less than set temp
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
FixinFax
  • 3085 Answers
SOURCE: GE profile oven will not heat up past 100 degrees.
You need a new control panel circuit board.
Easy to replace.
Search www.repairclinic.com
Posted on Sep 09, 2009
mgprice
  • 744 Answers
SOURCE: GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Posted on Oct 01, 2009
  • 715 Answers
SOURCE: I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Posted on Oct 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Posted on Oct 30, 2009
Why is a Kenmore elec range model 665.92004102 have oven temp lower by 100 deg at settings of 400, 450, 475 and 495; while off 150 at 350 deg setting?
There is a problem with the oven probe sensor or EOC. To ensure this problem is fixed both parts would need to be replaced. This could cost more then $300 to have repaired.
Apr 23, 2014 | Kenmore 95822 / 95824 / 95829 Electric...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
I have a GE wall oven that does not heat up to the set point. Model JKP13GP. 75-100 deg cooler. The temp prob measures a little less than what is required. 1.00 in ice water, 1.07 @ room temp and 1.27 in...
No the sensor is going to be the problem...at room temp it should be between 1060-1100 ohms. In boiling water it should be somewhere around 400 and in icewater it should be appx.2500-3000
The sensor needs to be replaced. The part number for it is WB21X5301 it can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
GENE
Sep 26, 2011 | GE Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
New oven thermostat acting nuts
can't find our model with this model # .. i would try cking the wiring / making shure it's correct . normal orp when heating the light is on . not heating light is off . although the thermo is new it may be bad / or possible that it not the correct replacement . hope this helped **** ..
Dec 09, 2009 | General Electric JBS07M Range
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven temp will not exceed 350 deg, also the timer does not work
Check the oven temp sensor with OHM meter. It should read 1100 ohms.
If not, replace it.
Otherwise the electronic control is bad.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas GEXL44: Oven does not work
oven never lights , but shows its on,? never heats past 100 deg?? soundslike a bad bake ignitor to me take down the model number and order a bake ignitor, installs on the bake burner, under the floor of oven, with just a few screws and 2 wires.
Mar 12, 2008 | Kitchen Ranges
GE Profile JB968SHSS Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
