Question about Canon imagePROGRAF iPF8000 Printer
Canon IPF8000 Error 2F1F
My plotter show Error 2F1F. I already changed the purge unit as service manual tells. But the error remains ... The strange thing on that issue is that this error came more and more often until it stayed permanent. So everyone would say "Purge unit is faulty" but as I said a new one didn't help. I did reset on the PurgeUnit counter but no change ... So before I change the mainboard - any other idea ?
  • John Ross
    John Ross Dec 13, 2013
    I was wondering if you ever resolved the issue? If so, what was the fix to rid the 2F1F error?
  • 3 Answers
SOURCE: Canon Pixma MP500 Multifunction printer copier scanner error code 5C00
he fix is in the problem
Posted on Feb 11, 2008
  • 79 Answers
SOURCE: error E141-4046
latest firmware update www.canon-europe.com
Posted on Apr 13, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP 830 I replace purge unit
You may need a new printhead now, or you may have left a foam packing block inside the new purge unit.
Posted on Oct 29, 2009
  • 79 Answers
SOURCE: I need to change the
first you must get the purge unit assy code for ordering.
The replace procedure is easy.
All you have to do is to remove the covers on the right side of the machine and loose the 4 screws that holds the unit on the chasis of the machine.
Watch for the ink that might be inside the unit
Posted on Jan 04, 2010
pineworks
  • 4041 Answers
SOURCE: Canon MP830 Purge unit sticking
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Print head error
i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- a.louloudis1@gmail.com for questions and support
Jul 03, 2015 | Canon imagePROGRAF iPF8000 Printer
What is Canon ipf700 error code hardware error 03130031-2f1f
I have the same error. I have been told that I need to replace the purge unit. Can I do it myself and save big $.
Jun 23, 2014 | Canon iPF700 InkJet Printer
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Facing 2F1F IN IPF750 MACHINE REPLACED MAIN PCB,PURGE
HELLO ,
IF YOU'VE REPLACED THE PURGE UNITAND STILL CAUSING THE TROUBLE, CHECK THE WIREING!
HOPE THAT HELPS!
Sep 10, 2011 | Canon imagePROGRAF iPF8000 Printer
Error 03130031-2f 1f ipf 6100
If you are lucky- air bubbles in the ink lines to the printhead(s) - which you can draw out using a syringe.
If you're UNLUCKY it's the purge unit, and it has to be replaced.
Nov 29, 2010 | Canon imagePROGRAF iPF8000 Printer
Error 03130031-2F1F
03130031-2F1F: Purge motor HP error - Restart printer in Service Mode (Roll/Sheet Feed Button + Information button and then Power On button) to check without Cleaning cycle.
Sep 25, 2010 | Canon imagePROGRAF iPF8000 Printer
Canon iPF8100 Error message E03130031-2F1F
check under the purge unit there is a gear that is out of his position.
you have to track it down by moving with your hand the right wheel.
Feb 08, 2010 | Canon imagePROGRAF® iPF8100 InkJet Printer
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
I need to change the printer head in our canon iPF 700. I have the new print head but, it will not let me change the head becasue the ink level it too low. We replaced all 6 inks last wednesday and only...
you can solve this error code by removing the purge unit (take care of the ink).
Then you have to turn upside down the unit to check the gears. There is a white gear that moves in the ''air''. you have to re adjust the gear to transfer the move normally.
Then the problem dissapears.
Also you have to check if the motor is still moving.
Jul 08, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon ipf8000 error code
Hold down the roll/media button and the info button while turning on, wait about 10 seconds and release roll/info buttons. You should get an S in the upper right corner. That puts you in service mode. Push menu then scroll down to maintenance then right arrow to head replacement. To get out of service mode turn off.
Jan 04, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
91 people viewed this question
old marine
old marine
