Question about Samsung 943NW Monitor
What is the number of IC 802 in samsung 923nw monitor
The ic starts with L.... it is 8 pin smd ic with its 5th pin grounded. probably of LD 7XXX series... it is not ld 7552, or 7575 or ld7576..pls someone .. this is suresh thanking all those who are going to give a solution
MARR
  • 49 Answers
SOURCE: SAMTRON 56V 15 in.CRT A41DC IC PROGRAM
replaced the memory with exact part number.if same problem exist ur system gone bad because u said that the 7805 failed(overvoltage) which is also the supply of system control. hope this help u...
Posted on May 17, 2007
SOURCE: SMPS IC for Samsung 753S Monitor
Can you help me about SMPS IC DP704c on jitendereco@gmail.com
Posted on Mar 03, 2009
MNfisherman
  • 11896 Answers
SOURCE: 923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Posted on Jul 09, 2009
budmrtn
  • 11361 Answers
SOURCE: Good day, my monitor's power
How do the DC filter caps look? no bulging/leaking tops?
You need to verify the DC output of the 5vd and the 12~18 for the inverter, you will plug the power into the wall outlet and turn off the monitor using the power switch, check the DC voltage (The power supplies will be runing the minute the monitor is plug into the outlet and you do not want the inverter circuits to be running so you can check the DC with the inverter off and on to see if the DC ouput is steady. Please post back what you see.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 13, 2010
budmrtn
  • 11361 Answers
SOURCE: My monitor won't turn on, no stand by led, ive
You need to have 5vdc (for logic) and 12~18vdc (for backlights) the minute you plug it into the wall outlet. It soinds like you main power is not working at all.
Here are the serivce manuals:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=740&kategoria=monitor&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Posted on Nov 29, 2010
Channel 1 makes a pulseating click and NO sound through it . All other channels are fine!!!!!!!!
Operational amplifier circuit named 4580 is the issue as with most of mixing boards, each channel has its own operational ic's and one way to know which one is defective is simply touch every one on the board, inside of course, of the non-working channel, check for excessive heat and if you find one pretty hot compared to other you just find your bad component, you will recognize what type of ic im talking about, is a 8-pin smd ic where the pin 4 should have -15v and pin8 should have +15V, no other pin should have any voltage and this is another way to test an opamp, with a dmm in dc volts referenced to ground, chassis ground, let me know if you need further assistance.
Sep 18, 2013 | Behringer XENYX 2442FX Mixer
Tip
SAMSUNG PLASMA POWER SUPPLY CLICKING.
If you have a Samsung Plasma PS50A550 which will keep clicking and not come on, the fault is in the power supply .Check Power supply if its a BN44_00222a. This PCB cost almost $ 300.00 can be fixed for around $ 30.
The fault is in the 5.3v supply to the T.Con PCB. On the Power supply check voltages.VS will not come on unless the T.Con pcb is active.
Check on printed circuit side of PCB on secondary side there are 3 IC close to one another. 2 IC'S are 8 pin and one is 16 pin. Replace both 8 pin reg IC (25h3ll ) these are available from RS components. Part number is STS25NH3LL. The 16 Pin IC is a L6725A but this is not faulty.
lets keep these good TV working for another 4 years.
on May 30, 2014 | Samsung PS50A550 50" Full HD Plasma TV
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
I need smd ic no mp14820s it is in dsl -2640u board
The number is MP1482
also check BD9328AEF
http://www.monolithicpower.com/Lists/Product_Synchronous%20Switcher_5717/DispForm.aspx?ID=97
Oct 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
At random my samsung ln-r268w will shut off and the power light will blink untill it dicieds to come back on
hi my lcd ic problem 8 pin z1021hai thise no finde in market please that ic matching number ic solve me thank you
Jan 22, 2011 | Samsung LN-R268W 26 in. HD-Ready LCD...
I have a proview lcd monitor model pl866s .What is the size of the power connector for the 19vdc @3068a psu?I have an extra psu with the correct voltage /current .Thanks Robert.
For the above LCD Monitor, I actually saw a small spark at the top part of the main board once the power input jack was connected. It prompted me to the exact location and when I check the SMD ceramic capacitor (that generated the spark underneath it) with analog meter set to X 10 K ohm range; it actually developed a slight short circuit. Replacing only the fuse and the SMD ceramic capacitor solved the no power problem in this 19" LCD Monitor. This Monitor uses the inverter IC (OZ960G), A1084-25CM (2.5 volts voltage regulator), AMC1117-3.3 (3.3 volts voltage regulator), ADC IC (MST8136B) and CPU IC (MYSON MTV312MV64).
Oct 07, 2010 | Proview PL 866s (Gray, Silver) 18 in. Flat...
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
My samsung tv startup with full volume
Its memory IC is gone needs to replace check model spec or IC log book for yours model or email brand services to get IC number i.e. 8 pin ic any one with soldering knowledge can do that
Dec 25, 2008 | Samsung DLP HL-P5663W 56" TV
713N samsung monitor; No display
Necesito Manual de servicio, con todos planos y circuitos, defectología
Nov 25, 2008 | Samsung SyncMaster 713N 17" LCD Monitor
Open Questions:
Hi! I have a problem with my Samsung 943NW Monitor. Recently I plugged in a thing which splits my sound input in two: one for a headset and the other for the loudspeakers. After done this my monitor d Recently I plugged in a thing which splits my sound input in two: one for a headset and the other for the loudspeakers. After done this my monitor driver just vanished, and I had a noname plug and play display and the 1440x900 resolution just vanished and was 1024x768 instead. When I tried to install the correct driver (which windows says I've sucessfully done) nothing has changed. I'm using Windows 7 64 bit, which was the only change in the late months around my com, so this MUST be related some way. When I tried to install the driver from the disc I have given along with the monitor itself, the installer says I need to visit samsung's website for 64bit and Vista drivers. No downloaded drivers worked either. Then, after hours of searching I just watching my messed up screen, then suddenly windows did something I still couldn't figure out, and everything was fine again! I had 1440x900 resolution and everything went well... until today... This all happened a few weeks ago, and now I had to move my come in my room from one point to the other, so I plugged everything off, moved it, plugged back in, and now I have the same issue, but still without a solution. If you need any other specifics just ask, and thank you for your help in advance! P.S.: In sort, the windows 7 64bit is messing with the monitor driver after I plugged in the jack thingie, but removing it isn't solving the problem at all.
Mar 01, 2017 | Samsung 943NW Monitor
Hi! I have a problem with my Samsung 943NW Monitor. Recently I plugged in a thing which splits my sound input in two: one for a headset and the other for the loudspeakers. After done this my monitor driver just vanished, and I had a noname plug and play display and the 1440x900 resolution just vanished and was 1024x768 instead. When I tried to install the correct driver (which windows says I've sucessfully done) nothing has changed. I'm using Windows 7 64 bit, which was the only change in the late months around my com, so this MUST be related some way. When I tried to install the driver from the disc I have given along with the monitor itself, the installer says I need to visit samsung's website for 64bit and Vista drivers. No downloaded drivers worked either. Then, after hours of searching I just watching my messed up screen, then suddenly windows did something I still couldn't figure out, and everything was fine again! I had 1440x900 resolution and everything went well... until today... This all happened a few weeks ago, and now I had to move my come in my room from one point to the other, so I plugged everything off, moved it, plugged back in, and now I have the same issue, but still without a solution. If you need any other specifics just ask, and thank you for your help in advance! P.S.: In sort, the windows 7 64bit is messing with the monitor driver after I plugged in the jack thingie, but removing it isn't solving the problem at all.
Samsung 943NW Monitor Logo
116 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
