Question about Car Audio & Video
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just snap the plugs into dashboard harness and place cd player in dash.
  • 111 Answers
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Posted on Jan 29, 2014
2 Suggested Answers
  • 45 Answers
SOURCE: kenwood KDC-322
Go to auto technician and repair it.
Posted on Oct 22, 2012
What's your problem?I drive a 1999 ford crown victoria. This unit did not come with a a wire harness.. so how do i install my Kenwood KDC-138 FM / AM Receiver correctly
you need to go to any appliance store that cells cd players and buy a wire harness that connects to the cd players wires its called a ford wire harness, the people at the store should know where and what it is.
Oct 17, 2011 | Kenwood KDC-138 FM / AM Receiver
My KDC-MP283 car cd player stopped working. The music turned off, the screen is flashing "protect" and it won't work. What's wrong with it?
The Protect message means that the player has identified a short circuit in the wiring to the unit or that a wire is touching the chassis of the car. You need to check the wiring and either rewire the unit or insulate the wire(s) to fix the problem. Then press the Reset button (below and to the left of the volume knob). If the error doesn't clear, you need to contact a service center because the short is inside the player itself.
The manual for the KCD-MP238 is available here: http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf .
I hope this helps.
Mar 18, 2011 | Kenwood KDC-MP238 CD Player
What wiring harness do I need that works 1996 Toyota Tacoma
Hello shonk_patric,
You'll have to go to Kenwood or to the audio dealer where you purchased the receiver if you do not have the harness that plugs into the back of the radio.
One vehicle specific aftermarket harness for a '96 Tacoma is the Metra 70-1761 available here at Crutchfield.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP228 CD Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Oct 11, 2008 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
