Lands Phones Logo
amir Posted on Oct 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keep flashing and no operation - Lands Phones
Anonymous
Level 3:
Master:
  • Master 444 Answers
  • Posted on Oct 24, 2012
Anonymous
Master
Level 3:
Master:
Answers
444
Questions
0
Helped
101513
Points
1275
Check the voltage on the battery after you tried to charge it .With a meter,Sounds like the battery is getting weak.
My gas furnace is working but the led light will not stop flashing, is it suppose to keep flashing.
A steady heartbeat on the circuit board USUALLY means normal operating condition.
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
2helpful
Can't download adobe flash player nor can I. View you tube material
Hi
You don't say which operating system you are using.
You don't say where you are trying to download Flash Player from. If it is not from the official Adobe site, then the source file may be corrupted.
Flash Player may be installed/partially installed but corrupted and the download can't rectify the corrupted files.
Flash player is required to view YouTube Video clips. This is why you cannot use Youtube properly until you have resolved the Flash Player problem.
Uninstall Flash Player and all its components in Add or Remove Programs > restart the computer > download and install the latest version of Flash Player from:
www.adobe.com
Restart your computer after the download > try YouTube again.
Update Flash Player regularly to keep it up to date (you should get regular alerts to update).
I hope this helps.
3helpful
Why does my flash shockwave keep crashing every 19
Its Not a Flash shockwave issue, your internet bandwidth is lo that’s wise this types of issue is coming on your system
Error mesage , windows xp pro , could not find macromedia flash
if its nline you need to install adobe flash reader.  search for it on google
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
2answers
Flash corrupt files
Uninstall flash player and redownload and install it from http://www.adobe.com/products/flashplayer/
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
