I tried to open in Safe mode and got this screen and then back to the configuration stage 3 screen and then shut down - on loop.
  • Allen R Oct 24, 2012
    Do you have the repair disc?
  • 40 Answers
You can use a repair disk to fix the problem, or there is another brilliant sollution.
If you have another computer you can use for internet access and a 2GB flash drive then take this option. Believe me it has its uses and it may come in handy one day.
>> Hiren <<
Posted on Oct 24, 2012
5 Suggested Answers
cpenzes
  • 1102 Answers
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Posted on Feb 09, 2009
SOURCE: My toshiba laptop m30 satellite will not let
if u reinstall in ur operating system.
Posted on May 04, 2009
  • 16 Answers
SOURCE: my new lenova thinkpad t400 seems to be caught in
Hello!
This is a tough one. I've seen this recently and had to just press and hold the power button to shut down. Not good!
I'm assuming you're using Windows of some sort since it shows "Stage 3 of 3" when it does updates during shut down.
What has happened is you downloaded some sort of "fix" from Microsoft and it's getting stuck while trying to install. I've had this happen and have never found a good solution for it.
1. Turn you computer off.
2. Turn your computer on
3. As soon as the power comes on, start pressing F8 repeatedly.
4. When you get a black and white menu, use your arrow keys to move up and down, select "Last Known Good Configuration" and press enter.
What the solution I've provided does is revert your computers software to a point in the past, hopefully just before you received the screwy update.
Make sure to rate the solutions you get!
Posted on Aug 08, 2009
  • 46 Answers
SOURCE: Restarted computer and it will not start
If you have a recovery cd, use that. Set your bios to boot from cd.
Sounds like the hard drive has crashed and you may have to reformat it and reinstall the OS...or change it.
Posted on Aug 14, 2009
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
Hello my laptop seems to be looping
Try with the Last Known Good Configuration. if that does not work. back up imp files frm the desktop, My Documents n C:\ drive. perform a repair installation on the C:\ Drive alone. this should fix the issue. as some boot files are corrupted.
Mar 02, 2010 | Toshiba Satellite Pro L300 Notebook
Stuck on the opening screen
try going to safe mode first... upon turning on your laptop, continuously press/ hit F8 key until it gives you options then select safe mode... after you're able to log into safe mode you can try and run a scandisk check or try to restart the computer to see if it would work in normal mode...
hope this helps you...
Nov 15, 2009 | Acer Aspire One PC Notebook
My Dell laptop is stuck on Windows Vista Home Basic
Press F8 to go to Safe mode, open SYSTEM RESTORE to go back to checkpoint where not yet updated the system.
And next time to open back your system normally finished all updates before you shut down.
Sep 16, 2009 | Dell Inspiron 1525 Notebook
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
How do I get my Acer 5500 to boot from my uTorrent recovery disc?
Do you have your original recovery media for Vista? Sounds like you're going to have to repair the installation.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
When I switch on Acer Aspire 5315 get message "Configuring updates 3 of 3 0% complete" for a few second then pc shuts down restarts and goes back to the same configuring updates message just...
try starting the computer in safe mode. As the computer boots keep pressing F8 until you hear a beep. The computer will or should start in safe mode, once it has everything will look big, don't worry about that for now, click on start>programs>accessories>system tools>system restore and choose a date for when you know the computer was working without any problems. Once the computer has restored it will shut down and reboot. When/if asked what mode you want to boot/start your computer choose start windows normally. I hope this helps.
Oct 22, 2008 | Computers & Internet
I have an acer aspire laptop, when i start it up its says configuring updates stage 3 of 3 0% complete then it will shut down come back on say the same again and shut down again. it will keep on doing this
Maybe you could try the last known good configuration. When the laptop is starting up, wait until the acer screen disappears and then tap F8 on the keyboard before the windows screen comes up. You should get a black screen with some options that say safe mode. The fourth or so option on the list will be "Last Known Good Configuration". The computer should try and load windows. Hopefully that will restore the machine before the update.
If it works it would be a good idea to go to http://windowsupdate.microsoft.com/ and fully update your laptop. This will download the update manually instead of doing it with automatic updates.
Oct 14, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
