Question about Fuji FinePix S2980 HD Digital Bridge Camera
Why only two settings on my s2980 for d.o.f.
Trying to get narrow d.o.f. for close up, standing 1m away, screen shows ref af flashing on manual. camera only offers two settings on manual f3.1 and f6.4 not allowed to take it below f3.1
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
The lens on the S2980 only opens up to f/3.1, and that only at the wide end of the zoom range. At the wide end the only available aperture settings are f/3.1 and f/6.4. At the long end they are f/5.6 and f/11. See the specifications on page 119 of the manual.
In general, compact cameras simply do not give you the control that larger (heavier, more expensive) SLRs do.
Posted on Oct 24, 2012
2 Suggested Answers
  • 540 Answers
SOURCE: WHEN Y0U TURN THE CAMERA ON IT SHOWS !ZOOM ERROR
The lens is jam you can try to tap the below of the cam slightly but do not apply force or you can try to power off and on few times or take out the battery and charge it full and then try once if the problem persist please take it to any service center.
Posted on Feb 16, 2010
Camera takes blurry pictures up close and sharper ones from afar. Camera will not focus on specific object either.
There is a "close focus" limit, depending on your lens. The standard "kit lens" won't focus closer than about 2 feet away. Check that the switch on the lens is set to "AF" not "MF" "MF" means, "manual focus".
When you lightly press the shutter button, the viewfinder should blink with little dots/squares indicating what it focused on, and beep. If it doesn't, and you are set for "AF", then your camera needs repair.
May 10, 2015 | Canon EOS 600D Rebel T3i Digital Camera
Estimated time remaining readout shows AF instead of the time left. It is a Kenmore 700 series dryer
AF stands for Algorithm Failure, which means that there is something preventing the dryer from calculating the remaining time. Try cleaning out the dryer drum and lint screen completely, then run the dryer with just a dry towel.
Feb 20, 2015 | Kenmore Dryers
Stuck in AF-ILL ONLY mode
Is the flash still on the camera when you do this? If so, check your camera settings as well as the camera may be over-riding you.
If the flash is not on the camera, some of the settings for custom settings can only be changed with it on the camera via camera commands.
If you do not have the manuals, you can get them here:
http://www.nikonusa.com/pdf/manuals/Speedlights/SB-800.pdf
http://www.nikonusa.com/pdf/SB800_techniques.pdf
Feb 19, 2012 | Nikon Speedlight SB-800 TTL Flash
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
When I turn camera on to take picture, I get a screen that says "1M 423". It is set on "Auto" which is also indicated on the viewing screen. How do I fix it?
"1M" stands for 1 megapixel. The camera is set take pictures in 1280x960 pixels mode. To change this press the F button and select another mode. 6M is the highest quality, but will reduce the number of pictures, you can take before the card is full. "423" indicates available space on the card. This number gets lower as you increase quality.
May 26, 2010 | Fuji FinePix S5000 Digital Camera
AF keeps showing up
AF is an AIR FLOW issue, youll need to check your venting for an obstruction.
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
AF assist lamp on 3100z?
The 3000Z does not have AF assist, and I assume the 3100Z does not have one either.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
The pictures I take with my Kodak digital camera are not clear
One or more causes may result in unclear (blurry) pictures. Some common causes and suggested solutions are listed below. The lens is dirty. Clean the lens according to the guidelines for your camera model. The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera model has recommended distances for normal, telephoto (zoom), wide-angle, and close-up pictures. The subject was farther than the effective range of the flash. Each camera model has an effective flash range. The camera did not autofocus or autoexpose the picture correctly. For best Autofocus/Autoexposure function, press the shutter button halfway down and hold. When the AF/AE Indicator (Ready Light on some cameras) turns green, press the shutter button the rest of the way down to take the picture. If the yellow light blinks, release the shutter button. (On some models, the light will also blink yellow if the shutter speed is too slow.) You did not use the LCD screen Preview feature to take a picture in Close-Up mode. When the camera is in Close-Up mode, always use the Preview feature, both to confirm focus and to aim the camera properly. If you do not do this, the viewfinder will not show you an accurate view of the picture because of parallax error. The subject or camera moved while you took the picture. Place the camera on a flat, stable surface, and hold the camera very steady. Or use a copy stand or tripod – especially advisable at telephoto or high-zoom settings, or in low light.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Fuji FinePix S2980 HD Digital Bridge Camera Logo
103 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
