Question about Stihl Hs45, Hs 45 Hedge Trimmer Bottom Gear Box Cover Part 4228-641-0400
Excessive fuel consumption
The engine sounds ok but fuel consumption has become excessive
  • 718 Answers
Carb needs to be tuned. check your local repair shop.
Posted on Oct 26, 2012
Why my vito 115 using planty diesel
change fuel filter + clean egr valve
Jul 10, 2016 | Cars & Trucks
My Hyundai 1999 model CHECK ENGINE LIGHT IS ALWAYS ON AND THE FUEL CONSUMPTION IS HIGH.
Do you have black smoke or what looks like soot coming out of the tail pipe. The check engine light monitors fuel pressure through the computer and pressure regulator. It will come on if the pump pressure is too high or too low. If the pressure regulator is faulty it could cause excessive fuel consumption,
Jan 19, 2015 | 1999 Hyundai Sonata
If my fuel consumption is high. In what area I do have to check other than basics? 1. No error code 2. fuel filter not changed. 3. O2 senses test through torque app. Wave form is ok (0-9 sine wave
Check things other than the engine like; tire pressure/alignment, brake drag, transmission operation, excessive drag on any of the accessories (PS pump, AC compressor, water pump, alternator). Anything that is significantly hotter than the other side or something right next to it is worth looking into
Jan 02, 2015 | Cars & Trucks
How do i rebuild a mitsubishi l300 fuel pump
Don't sound like a fuel pump,replace fuel filter and see if it fixes.
Jan 05, 2013 | Cars & Trucks
1997 Hyundai Elantra has excessive consumption of gasoline, every time the tank is almost full the check engine light turn on. Also the air bag lights is on.
HAVE VECHICLE SCANNED FOR FAULTY EVAP CANISTER PURGE VALVE IT NOT CONTROLLING EXCESS FUEL VAPORS..THAT WILL CAUSE LOT OF FUEL CONSUMPTION.
Feb 06, 2011 | 1997 Hyundai Elantra
Excessive consumption of fuel of daewoo matiz and cutting off
Sounds like the Oxygen sensor in the exhaust may not be working effectively. Check the connections and wiring running to it. The Oxygen sensor only starts to work when hot so be careful. The sensor outputs a pulse of voltage when the engine is running. If the voltage output is steady then it needs replacing.
May 28, 2010 | 1999 Daewoo Lanos
No power and high fuel consumption
Sounds like catalytic converter.
Mar 30, 2010 | 1992 Isuzu Rodeo
Excessive fuel consumption. This happened a year ago and then rectified itself. 12 months later, it is happening again. This time the engine picture light came on. I put in a new air filter.... Is this a...
If your Jeep is equipped with a 4.7L V8, go to check each ignition coil and spark plug careful. It's a problem at all. Coils are ofter misfires to the engine head housing. Check the pressure of your fuel system too. next problem to this engine are the injectors. There is a little filter inside of each. it can't be replaced, but cleaned. If you remove the injectors you need to see the same spry picture on each of them. If one injector don't spray correct, replace him.
Jan 26, 2010 | 2003 Jeep Grand Cherokee
Excessive fuel consumption,no power on incline,
this could be an air intake problem, check the air filter but what ive seen before is the flexible intake pipe collopse only when the engine was under pressure as you describe.Try removing this pipe & driving again but not for long as dust would enter the engine .it might confirm or elimiate this.
Aug 16, 2009 | 1985 Ford Ranger
Stihl Hs45, Hs 45 Hedge Trimmer Bottom Gear Box Cover Part 4228-641-0400 Logo
175 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
