Question about Miele G880 Dishwasher
All the sequence lights flash simultaneously when I set to wash
Cycles. The rinse and hold is operating normally. When we try to run any of the wash selections the lights just flash yellow at us. Not lights come on in the "check" area.
I did do a filter clean and rinsed out the removable intake valve.
This dishwasher has been in service since 1996.
  • kirksiffs Jan 02, 2009
    Problem solved! I just got off the phone with a local repair man who talked me through the fix. Involves pushing the top solo button and turning the dial to different cycles to reset the "Heat Fault function".
    Yay!
    I had a feeling it was more of an electronic problem rather than a mechanical one.
    What he cautioned me about though is to make certain that we do not let any soapy (Dawn or Joy) dishes get in there or sponges that have liquid soap or to not wash items such as furnace filters in the dishwasher. This can cause a sensor to go off and overheat the machine setting off this fault.
    It was a pretty easy fix, but unless you are a tech with a manual in front of you, it is a challenge for the everyday homeowner.
  • 14 Answers
SOURCE: Intake/Drain red light comes in and shuts down during wash cycle
You will more that likely have a faulty waterproof inlet system
Posted on Sep 13, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
  • 210 Answers
SOURCE: MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Posted on Jun 01, 2008
Illeagle
  • 525 Answers
SOURCE: Hotpoint BCI450 Programme cycles
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. From this link you can identify your issue and order parts to repair your unit.
http://www.repairclinic.com/0088_9_1.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
  • 423 Answers
SOURCE: My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Posted on Apr 11, 2009
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
Kenmore Dishwasher Model 665.11643300 Cycle will not run. Normal Wash light blinking Cancel light will also blink (but can be cancelled by holding button down) I tried shutting down the power and...
I will look a bit further in detail about your dishwasher problem. I am assuming you have checked the inlet water tap to the dishwasher is turned on.
Sep 14, 2010 | Dishwashers
The hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
DO NOT MIX DELIME ACID, RINSE AGENTS OR OTHER ACID WITH BLEACH PRODUCTS, OR HAZAEDOUS GASES WILL FORM.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
DO NOT LEAVE THE ACID IN ANY LONGER THAN RECOMMEDED.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Jan 09, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Miele G880 Dishwasher Logo
65 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
