Question about Xerox Office Equipment & Supplies
I cannot release the left margin on my Xerox Memorywriter 6015
I hit return, then while pressing the green code key I press the left margin key, but the margin does not release. The green code key works with every other function. Could the typewriter be broken? Or did another user mistakenly save settings that hopefully I can undo? Would appreciate some help. Thanks!
  • Olga Seng Nov 06, 2012
    Thanks, ****. I meant I press the margin release key, not the left margin key. Any other suggestions?
  • Xerox Master
  • 3,594 Answers
When at the L. margin press the Mar Rel key not the L. mar key.
DickyO
Posted on Nov 01, 2012
    Sorry, I meant that I press the Mar Rel key, not the left margin key. Any other suggestions?
JUSTOLDJIM
  • 454 Answers
SOURCE: Right margin won't release
Try touching the margin release key then the space bar to pass the margin then reset it in a new location with the right margin set key
Posted on Oct 17, 2007
JayBlair
  • 328 Answers
SOURCE: Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Posted on Aug 18, 2008
  • 3594 Answers
SOURCE: Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
  • 11 Answers
SOURCE: Need help releasing margins on an electronic typewriter.
Did you hit the MAR and REL buttons at the same time?
Posted on Sep 04, 2009
  • 14 Answers
SOURCE: My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Posted on Oct 14, 2009
I cannot release de left margin on my Xerox Memorywriter 6010. I press de Mar Rel Key and don't have success. Please, Help
Have you tried oiling it w/3-n-1 oil? Often the sticking problem is nothing more than it needs lubrication.
Feb 11, 2015 | Xerox 6010 Memorywriter Electric...
How to release left margin
Clear button.
I had a Xerox Memorywriter - great keyboard, so I know the sequence of press button, generally.
What to do.
... to what...
execute
does that help?
if this doesn't help i'll give a 2nd shot.
AK
Aug 28, 2014 | Xerox 6010 Memorywriter Electric...
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
How can I release margins on my XEROX memorywriter 6010
Get to the margin you wish to change Hold the code key, the key with the green oval and press thr top L. key that says mar rel in green, space or backspace to desired position press R. or L margin key depending on which one you are resetting.
DickyO
Apr 07, 2010 | Office Equipment & Supplies
I lost the manual for my sx-4000. How do I release the margins.
  1. Press "return" key to left margin.
  2. Press "margin release" key once.
  3. Backspace to where you want the left margin
  4. Press "Margin left" key.
For right margin, space bar to where it is, press margin release, space bar to where you want it, press "margin right" key.
Dec 10, 2009 | Office Equipment & Supplies
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
Reset Margins
on the upper L.H. side of the key board ther is a button marked MAR REL. turn typ. on press the return key then press the MAR REL key back space to move the carrier backwards or space bar to go forwords. when you are at the spot you need to be fined the button that reads L MRG. press it know your left hand margin is set,
know space the carrier over to the left by the space bar if it stops befor you whant it to press the MAR REL button space to where you whant.
now you have another button saying L MAR
press that and you left hand margin is set. Or the R MAR has small green letters saying L MAR if so you need to hold down the CODE key wile pressing the R MAG key ( any thing in green on key board can only be actavated by the code key ) hope this works
Jan 21, 2009 | Brother GX-6750 Typewriter
Changing Margins
Cannot find a picture of this keyboard however the process would be similar to this.  Move (return) the carrier to the left margin. Find the margin release key. It mat be labled M REL.  or M. R. or something similar.
  You may have to use it in conjunction with the code key, if this is the case the M REL or M. R. will be on the front of the key in a different color lettering.
 Press the margin release key and backspace to where you would like the margin and then press the left Margin key.   If these keys require the code key you will need to hold the code key down while pressing the release and set keys.
The right margin will reset in a similar fashion only space past the margin after hitting the release.
Hope this helps.
Oct 24, 2007 | Nakajima AX-150 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
269 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
