Hotpoint aquarius wml560 flashing lights and wont start
Checked pump checked pressure switch both ok
  • 3 Answers
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Posted on Dec 01, 2008
  • 662 Answers
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Posted on Jun 04, 2010
huuum
  • 750 Answers
SOURCE: Wash enhance light keeps flashing
Dear penzance,
Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, Wash enhance light keeps flashing on Hotpoint WT540 Aquarius 1400, have emptied pump filter and cleaned interior.
It keeps coming back, have switched off
Try this method to reset your system as we sometimes do with our computer when it reacts strangely.
As with an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Huuum.
How old is the appliance?
Please remember to leave a rating when you finish!
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
Posted on Sep 23, 2008
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
reddyanantha
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
Pump not starting
if not tripping the safety fuse
could be a pump problem or faulty line pressure switch
would test motor separated from the pump
Jul 06, 2016 | Garden
How to troubleshoot a no fuel problem, no fuel at fuel rail in a 2000 olds sillhouette.
First check there is battery voltage to the pump and the pump starts when the ignition is switched on , if not check fuse and relay, check wiring from relay to pump. If ok and the pump is working , check for fuel blockage from the tank inlet to the pump , some have a sock type filter in the tank pick up tube, if all ok remove the fuel filter , switch on and fuel should flow at the filter, fit a new filter, if still no fuel at the rail fit a fuel pressure gauge an check for low pressure , if ok, the fuel pressure regulator may be stuck causing a air lock replace it.
Apr 15, 2015 | 2000 Oldsmobile Silhouette
Oil light flashing
oil light means loss of oil pressure.. not good ..check oil level fill to full if low..low oil pressure will cause fuel pump to be shut off..
Dec 08, 2013 | 2001 Ford Escape
Raypak 2100 turning off and on
check gas pressure if ok check flame sensor if ok check pressure switch make sure making contact or loose wires to pressure switch
Oct 03, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My Frigidaire front loading washer GLTF120AS0 stopped draining and does not appear to be clogged. Is this an easy fix or should I just get a new one. It is only 6 years old
Hi.
If you are absolutely sure that the drain system is OK, then check the pressure switch, wiring and pump. The pressure switch detects the water level and determines when to start and stop the pump. The switch is located in the control assembly and it is connected to a long thin rubber hose that goes inside the tub. Try cleaning the pressure hose or replace the switch.
The pump must be tested reading volts or Ohming it to check the motor is good. Wiring is also tested using an Ohm meter. Check also the drain hose at the back. If its height is incorrect or if the hose is kinked you may get no drain. If all the rest is OK check voltages at power board.
Unless you have technical training I do not suggest carrying tests with power on. When you check the pressure switch look inside the control assembly. There should be a technical sheet with the description of the diagnostic cycle for the specific model. Clean pressure switch and try running a diagnostic.
Regards.
Ginko
Aug 08, 2011 | Frigidaire ATF6000ES Front Load Washer
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Fuel pump relay switch not working/ fuel pump emergency switch?
weak fuel pump,or cloged filter,or bad fuel pressure regulator!!!
Feb 24, 2010 | 1992 Mercury Cougar
My hotpoint aquarius WML560 DOOR WONT OPEN EVEN WHEN DOOR RELEASE LIGHT IS ON
take the bottom front panel off and pull down on the green plastic cable on the left side
Dec 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
977 people viewed this question
Top Washing Machines Experts
