How to load film onto projector - Computers & Internet
  • 3,799 Answers
A projector is not a "Computer" also you would need to give an indication of the make and model number.
Posted on Oct 25, 2012
I need a manual for Bell & Howell Lumina MX60 for an elderly person - need instructions how to load film.
Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
Dec 30, 2016 | Bell & Howell Cameras
How to load a Sears du all 8 1973
Sears 8mm projector with 1950's & 60's films - YouTube
? 13:24
https://www.youtube.com/watch?v=7-IIS8ti7Ig
Jul 5, 2011 - Uploaded by drh4683
Vintage sears automatic projector. ... All 8mm and 16mm movie film, even going back to the 1920's and 30's ...
Sears Du-all Eight - Demo - YouTube? 0:37https://www.youtube.com/watch?v=WHbqCMKUGkoNov 13, 2007 - Uploaded by fierorcr86Buy This Now at www.mycurrentauctions.com I demo a Sears Du-all Eight super 8 ... How to load a Bell ...Sears Du-all 8 auto thread projector - YouTube
Jan 01, 2016 | Office Equipment & Supplies
How do transfer 8mm film to dvd yourself?
If you have time, you would project your film onto a screen, and use a video camera to capture the show. Likely, you will get rather poor quality.
When professionally done, each frame is captured separately and made into a video. Better quality, but it takes a bunch of equipment that's expensive.
Oct 06, 2015 | Bell & Howell 10,000 Ft 8 Mm, Super 8,16mm...
How to load and view with a gaf 2388 projector
Usually there is a series of clips or levers of some sort that allows the film to pass around the sound drums and alignment path behind the projector lens. There is usually a line printed inside the projector to show the thread path for the film around the various mechanisms. But before you do that you might want to consider finding a photo shop that converts the film to a CD format. All of the old film media breaks down over time and you may be able to enhance it, preserve it and avoid burning it up in the projector(a common occurrence in those days) all at the same time.
Apr 29, 2015 | Cameras
How do I stop my Dad's Bell & Howell projector from "skipping" while running a film, model L, design 122.
For a projector to run right, the motor has gear teeth in it that engage with the hollow points on the film itself. The motor has to turn at a steady speed with no friction or hesitation. It is possible the motor on the inside of the projector needs to be oiled or cleaned out...or rebuilt at worse.
There is also the motor that pulls the film thru the projector and winds it onto the receiving spool. Sometimes that motor is out of synch with the projector drive motor and trys to pull the film thru to fast or turns to slow and the you get that "clicking " sound when the receiving spool isn't winding the film up fast enough and the film gets dragged on by those projector teeth and make that plastic clicking sound.
Watch the film while it is running between the two reels and the projector lens. The film should be slightly taunt going into the projector and slightly taunt coming back out of the projector. If you see the film grouping up in front of the projector drive or after, then you know your spools are needing greased up or there is a drag on the motors causing things to be unsynchronized.
This is definitely a mechanical problem and you need to watch the film being fed into the projector and how it is wound up n the receiver spool to see where the fault lies.
Feb 23, 2015 | Bell & Howell Service Manual: Model 122...
I have a minolta autodual 8 film projector but the front reel is turning backwards in the wrong direction. How do I change the direction to turn in the same direction as the back reel.
I assume you haven't put a reel of film onto the projector and looped it through to the back spool. The front spool usually 'freewheels' whilst the film is pulled through the projector and taken up by the motor driven rear spool.
It is possible that the friction drive and/or drive belt have deteriorated with age, as the mentioned projector is a rather elderly 'classic' of the dual 8mm series.
If in doubt, don't risk your family pictures. Try the unit with an old piece of film on small spools.
Dec 26, 2014 | Eumig Imperial P8 Movie Projector For 8mm...
Loading film
Hi Jacqueline, While I haven't used the particular model you have asked about, I "Googled" the Sears Du-all & got many hits. One of the hits was a UTube demonstration of a working Du-all. The link to it is the first link below. I also found a Sears database that details the manual number, lamp information, etc. That is the second link below. Take a look at these and other links you get when you Google "Sears Du-all". I hope this helps !!! Jim
http://www.youtube.com/watch?v=WHbqCMKUGko
http://www.super8data.com/database/projectors_list/projectors_sears/projectors_sears.htm
Mar 27, 2014 | Sears Du-all Eight 8mm Projector...
How to load the film
http://www.craigcamera.com/lit_b.htm. This is the cheapest I could find for your actual owners manual. I hope it helps. Steve
Dec 15, 2008 | Electronics - Others
Belle & Howell Super 8 Projector model 254RS loading problem
Don't have the motor switch in the still position when loading -make sure it is on FORWARD. Look at the little holes in the film and make sure the film is on the same side as the little grooves on the drive gear.
PS -let the bulb cool off before try to move the projector ,the bulbs are very expensive and hard to find.
If you do use the still position to view a frame do it for just a few seconds or the bulb will burn the film. Good luck- Tom.
Jun 21, 2008 | Bell & Howell Photography
Computers & Internet Logo
David Payne
David Payne
