Question about Pentax Optio Cameras
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
The camera has been looked after but only used a couple of times a year
  • Pentax Master
  • 32,281 Answers
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Oct 25, 2012
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
  • 24 Answers
SOURCE: Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
Posted on Sep 11, 2009
Samsung digital cam SC-D363 don't charge or turn on
Sounds like a bad charger or not the right one. Maybe you got them mixed up with something else. Usually there are two plug ins and one is for charging the other is for operation while plugged in on the camera. I feel that it is the charger at fault and not the camera, or the charging port inside the camera. To test the charger for power take a 12 volt light of any sort from a car and connect it to the ends of the charger with pieces of wire and tape being sure not to allow the two to short out against each other or may ruin the charger. This test may be done while plugged in or plug it in once wiring and taping is completed to see if any power goes to the light indicating a bad charger which sometimes can wiggle the end and it shows power then one of the wires have come undone near the end. One can carefully take a sharp small knife and cut through the plug to re solder the wire back on or find a replacement plug in from a yard sale or cheap used electrical shop and splice in a new end being careful to not mix up polarity or this will ruin the device by putting the power in reverse polarity causing parts to burn out typically.
Dec 05, 2013 | Samsung Cameras
Scooter only moves a short distance, then stops?
If the scooter in question is a Pride Victory with on board charger ? ( you plug a mains lead into it ?) now what happens with this particular scooter as the charger starts to fail, it's not charging the battery correctly, if you have access to a multimeter DC setting , check the voltage from one of terminal of the battery to the other terminal of the opposite battery, now it should read at least 18 volts , 0 volts then you need to change from one terminal to the other and same for the other battery ,, now if it below 24v that's the problem because as soon as you put it under load the voltage drops to under the minimum working voltage for the controller , hope that makes sense so other-words you need to replace the on board charger , contact me and I show you a way to do this cheaply...
Regards
www.gewizrepairs.co.uk?fixya
May 31, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
How do I charge my Cannon Powershot S750 battery using the computer ?
You can't. This camera does not charge the battery in the camera. You need to remove the battery and put it into the battery charger.
If you no longer have the charger, a replacement can be obtained cheaply from Amazon. I like the "Universal" chargers, which have adjustable contacts and can charge any of the small lithium batteries found in cameras and phones. These are available for as little as three US dollars. Mine will plug into a wall socket or a car cigarette lighter socket.
Dec 14, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Olympus FE 4000. I purchased it this past year and it worked fine for a while but all of a sudden my camera shut down. I though the battery simply needed charging so i charged it. when i put it...
Yes, it's possible. Rechargeable batteries don't last forever. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
The best way to proceed is to buy a new battery, then try to charge it. If it charges and the camera works, problem solved.
If it doesn't charge, then you will need a new charger. The battery will not be wasted though, as it is always handy to have a spare.
If having bought both new battery and new charger you camera still won't work, then you will have to look into your warranty or return it to the shop- however that works in your country.
It is possible to check the voltage of the battery with a meter (you can buy a general purpose multi-meter cheaply) but this takes a modicum of skill and interpretation. Even a run down battery may show some voltage on a meter, as it doesn't draw much current.
Nov 03, 2010 | Cameras
Camera works fine with power supply cord connected. It will also charge the battery if connected to camera and power supply connected to ac outlet. Checked battery and it has 8.32 Volts stored in it after...
Your charger is probibly the problem i had a friend of mine that had the same problem but different camera i told him to get a new charger he did and it worked so yoyu do the same goodluck:) please rate this solution...
Jun 06, 2010 | Cameras
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Lithium ion battery won't charge
known issue, battery needs to be 'shocked" back to life. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Nov 04, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Cameras Logo
96 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
