Question about Apple MacBook Mac Notebook
Macbook fan is running and it has a white screen wont start
White screen and wont start
  • 3 Answers
I would suspect a hard drive or system failure. Try stating up from your system installation disk and running Disk Utilities on your hard drive.
Posted on Oct 25, 2012
Mac tells me to shutdown by pressing the power button and the screen freezes
Your MacBook is over heating. You need to put some cooling paste to replace the old dried up paste that is on the processor and video card before it burns out the logic board. Clean out the fan while your doing this also.
Jan 10, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macbook dropped ..now battery cord doesn't light up very much and flickers... alot..? Is this an easy fix? Or is this gonna cost some bucks..? What could dropping the macbook have done to it
macbooks are very expensive to fix if you take them to the so called genie bar. so try a mall store to fix it or if money i no problem take it to the apple store.
Jan 15, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
InstallatIon of Mac OS X 10.4.10
White screen issues on your Macbook are more often than not, an indication that you may have a connected peripheral or device which may be hindering your Macbook's normal start up function
What you need to do first, is remove all peripherals from (printers, scanners, USB drives etc.) and then reboot your Macbook.
If your Macbook starts up normally without a white screen, leave all the peripherals disconnected and see if you can proceed to run all of your software updates, in Apple menu>Software Updates, first, including updating to the final version of Mac OS X 10.4 Tiger, 10.4.11.
Once all of your updates are completed, then you will need to go through a process of elimination by connecting one peripheral at a time, then properly shutting down and restarting your Macbook with each device, to see if your Macbook goes to a White screen.
Depending on the number of peripherals you have normally connected to your Macbook, this may seem a little tedious at first. But considering how bothersome a White screen is, it will be worth it solving the mystery of which peripheral is causing the white screen and failure to boot up normally.
If it turns out that one of the devices you had connected was in fact, causing the white screen, this will be the opportunity for to research online, visiting the affected device's manufacturer's website or even use Google, to confirm if there are any known issues and/or updates available to address that issue.
There are other variables which can come into view with a white screen issue, but this is a good way to start in terms of working toward a viable solution to this issue with your Macbook.
I hope this helps, let me know if you have more questions.
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
Jan 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook wont start up after cancelled OSX install
insert your Mac OS dvd .. and hold down the c key as you restart. it should launch on the dvd's system and allow you to boot. in the menu select Disk Utility and run the program and see if it can restore your hard drive...
It may need to remount the drive...
Let me know if that helps...
May 27, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Boot macbook problem
Parallels won't have caused this, Bootxchanger might have but it's not likely. More likely is that you HD is faulty.
A largish number of white Macbooks shipped with faulty Seagate HD which, although fine to start with, started failing after about 1 year of use.
I've seen 3 in the last six months.
Thankfully the HDs in these MacBooks can be changed in just a couple of minutes, the bad news is that the data on the drive is generallycompletely destroyed.
Try starting up from your install DVD, but not do the install. After you get asked about language, at the next screen, go up to the menu bar and locate disk first aid. Run that - you may be lucky and it fixes it or you may not.
Apr 28, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
Oct 05, 2008 | Apple MacBook Pro PC Notebook
Macbook wont turn on
My computer used to do the same thing, I found out it was my motherboard / logic board and a hardrive combination. end cost $1500..so i bought a new Laptop. Go and get those things tested.
Feb 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple g 4 , fans stay on
Use your Backup disks  to run it and reinstall everything if possible
Oct 15, 2007 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Mac Notebook Logo
78 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
