Question about Hotpoint Aquarius WF220 Front Load Washer
How do I remove solenoids fro aquarius wml560
3 Suggested Answers
SOURCE: my hotpoint aquarius WML560 DOOR WONT OPEN EVEN
take the bottom front panel off and pull down on the green plastic cable on the left side
Posted on Jan 30, 2010
SOURCE: I have an Aquarius WML560 machine and would like
all lights on machine are flashing and programme has stopped
Posted on Mar 28, 2011
My Hotpoint WML560 won't run a full cycle.
Is there a no spin button that has been pressed. Also some delicate cycles have no spin as part of the program.
Dec 14, 2014 | Hotpoint Washing Machines
I have hotpoint aqurieus WML560 will not drain how do i do this manualy
To get rid of any water still in washer, lay drain outlet hose to floor level, and the water should run out through gravity into a bucket or similar.
Once empty, remove the lower rear pamel of washer.
Remove large black hose on to pump.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Washing Machines
My hotpoint aquarius WML560 DOOR WONT OPEN EVEN WHEN DOOR RELEASE LIGHT IS ON
Dec 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine wont rinsewhen i put it on for a wash
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports (especially on the cold water side). The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Keeps going to f-03
  • F03 - Wash thermistor open/short circuit
If this error persists it's usually best to call fro service unless you are familiar with this kind of work.
Apr 18, 2009 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
19 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
