Question about ASUS R300 Portable Satellite Navigation Bluetooth Car GPS Receiver
Road r300 when i press the gps button it keeps coming up cant find roadcomnavi.exe
I cant see the roads in my gps . it just come blank it only shaws the vehicle . what would i do ?
The map may have become unselected.
Press TOOLS
Then press SETTINGS (or LOCALE on some models)
Press MAPS
Then press MAP INFO at the bottom of the screen.
The name of the map should appear with a tick beside it.
If there's no tick then it's unselected. Press the map name and the tick will appear. It should be ok then.
Sep 12, 2010 | Garmin n?vi 265WT Car GPS Receiver
Sevice required parts in side my printer are at the end of there sevice
Press the stop button and maintenance button both together keep prested for about 30 sec I tryed it and it worked for me. R300
May 21, 2010 | Epson Stylus Photo R300 InkJet Printer
Garmin is unresponsive. Won't power up or turn
I have a Garmin c340 that would not turn on.
I found the hidden reset button and it works now.
With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
Mar 10, 2010 | Garmin StreetPilot c340 GPS Receiver
Will not print i have renewed the ink it is a epson r300
Hi there you can try this it may work
to cure fault on r300
press and hold 3 buttons
stop, power &
Maintenance (the one with red light over)
for 10 seconds
a message will come on screen
counter is reset and turn off
turn back on
bingo she is as good as new
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Epson Stylus Photo R300 InkJet Printer
Printer showing error as paper jam
This means the IR indicator is dirty with ink or something. You need to clean it.
I wish I could post pictures to show how to do this...
Feb 28, 2009 | Epson Stylus Photo R300 InkJet Printer
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
Epson r300
Power on...press advance button....press down arrowed button until options in printer screen stops...press maintenance button....ink cart replacement appears in window ...press OK
Jul 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
ASUS R300 Portable Satellite Navigation Bluetooth Car GPS Receiver Logo
23 people viewed this question
Top ASUS GPS Experts
Jerry Umali
Gil Shultz
Are you an ASUS GPS Expert? Answer questions, earn points and help others
