Need manual on zenith 29CT30, want to know how to turn on turntable
Need asap if not will be junked and nothing wtrong with it that i know of
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Try this link to download it.
Posted on Oct 25, 2012
Old Zenith Allegro Console Stereo (made in England). - Turntable will not turn; tone arm does not move, even on "manual."
remove the flat rubber platen cover to expose the lock ring at center (horseshoe clip) remove this lock ring and pull the platen straight up and off , under there you should find a rubber tire and the drive motor shaft , turn unit on , you should see motor turn and then it should move rubber tire , if not , your going to need to replace it or clean it up and lube it
Jun 06, 2017 | Zenith Audio Players & Recorders
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
I have a zenith console turntable and the radio part and speakers work just fine but when i turn the dial to phono all the lights go off like nothing works and the platter doesn't spin
The turntable is probably frozen and needs to be serviced. The platter need to be removed and the old grease removed and new grease applied. The rubber idler wheel may also be hard and it should be soft, This wheel turns against the platter and is attached to the motor. All of this is located under the record platter after the rubber mat has bee removed.
Aug 10, 2013 | Audio Players & Recorders
I recently purchased a old Zenith stereo and turntable console. I am not sure what year it is . The model number says # Y804 and there was a nother number 8YTO2 which has the word chassis after that...
I have one of these with the number. I bet the turntable would work with yours. If you havn't fixed it please e-mail me at marc.lajoie2013@gmail.com
-Thank you and please let me know asap
Nov 25, 2010 | Zenith Audio Players & Recorders
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
Vintage Zenith Turntable starts record in middle.
Check the speed it is set at as the speed setting tells the turntable what diameter of record it will be playing.
Aug 30, 2009 | Audio Players & Recorders
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
