Question about Acer Aspire 7741z
How to fix cd drive
Cd ejects before burn is complete
  • Lastoni Wibowo Oct 25, 2012
    try to reinstall the software that you use to burn cdi hope this will helpthank you
  • phkatz6
    phkatz6 Oct 30, 2012
    The error message I received says "Windows Media Player encountered a problem while burning the file to the disc." It appears once the burn is almost complete.
  • Acer Master
  • 2,878 Answers
You may be using too many processes or resources while burning. Close all other application and disable screen saver. Only use the recording software while burning, and burn at a lower speed.
Posted on Oct 25, 2012
  • phkatz6
The cd burn function and the eject function do not work, all other features work normaly
CD drives wear out as well as other things. If it isn't burning then it amy be time to try and update the drive firmware. if that doesn't fix it replace the drive. You can buy DVD burner for about 13 GBP.
Apr 12, 2013 | Tascam DP-02 8-Track Digital Recorder
I HAVE A PRODUCT KEY AND WANT TO DOWNLOAD IT TO THIS COMPUTER BUT THE DISC ISN'T WORKING
you need to do a lot of test, 1. check in bios if your cd-drive or dvd- drive is in enable if not enable it. 2. if your cd drive was enable, try to insert another cd, if the cd you insert was read by cd- drive, the problem is your cd. then if the other cd you insert is also din't work the problem is the cd-drive or dvd- drive. :P
Aug 25, 2011 | Microsoft Office Professional 2007 Full...
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
I'm having problems ejecting cd's from laptop after they're done burning.
Hi
If you go into the computer and open it look for the cd/dvd drive
highlight and right click it and go down to the properties
now click on recording up in the top right hand side of that box
then go down to and put a tick in the box where it says
Automatically eject the disc after a master burn then restart the laptop
this should then automatically eject after a burn
if it don't then
click on your computer icon
it should open it up and show you your hard drive/s
also the cd/dvd drives
if you highlight the cd/dvd drive then right click it and go down to eject hopefully this will eject it
also there is a small pin hole just beneath the push eject switch on the drive itself if you push something thin in there gently but firmly it should also eject the drive
hope this has helped you
please let us know if fixya has fixed it for ya
Jan 30, 2011 | Dell Inspiron 1545 Laptop
Hai i've dell Inspiron 640m laptop, i'm unable to write a cd/dvd. i'm using nero 7.0 version which i've installed it's showing the burning successfully but after completion of burning the CD/DVD is not...
in the Nero option look for the option "Do not eject Disk after burning" when u chose the disk buring option.check the image , if u chose this the disk will remain the CD/DVD drive...then after a few mins when Nero comes back to life(Some times it hangs) so the CD gets corrupted....just use the eject button on the CD ROM drive...it should be ok
Also try to use CDRW disk that way u can re-use it
Jan 04, 2010 | Dell Inspiron 640m PC Notebook
My Cd burner is not burning a complete disk
the ans is simple tht burn the project again on an fresh cd and play it
Dec 20, 2009 | Toshiba Satellite M55 Notebook
Compaq Presario 5200CL: CD Drive will not open when told to or when button is pressed on tower. Tried to burn data on a CD-R, but when completed, wouldn't open... Drive works, info on disc, just can't get...
There is a small hole on the CD-Rom you can straighten out a safety pin and push it in there. It will eject the CD. Hopefully it will then fix your problem.
Sep 20, 2008 | Computers & Internet
Finished cd's
get checked in itunes options or settings whether the ejection of the drive is check marked or not..
Feb 05, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer Aspire 7741z Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
