Question about Pool & Spa
We are having difficutly in wiring Tripus switch drawing reference 850-609, Myford Pt No. 85756 to Crompton Green Ltd motor Ref GF7.971, a 1/2 HP capacitor 240V. We need to know position of the internal shunting loops
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
  • 4088 Answers
SOURCE: 1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Posted on Aug 23, 2009
  • 308 Answers
SOURCE: wiring diagram for electricmotor with capacitor
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Posted on Apr 01, 2010
Testimonial: "Thankyou for your assistance,very helpful."
  • 44 Answers
SOURCE: I have a 2hp 2
If this is a new install, re-check your wiring, If not you have a bad motor.
Posted on Sep 28, 2010
SOURCE: I have a 1/3 hp motor with a capacitor. There are
I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
Posted on Mar 01, 2011
Chrysler town&country after overheating getting p1491 code how to resolve it ?
Start your diagnosis at the fan relay module which is located below the battery box on the left frame rail. The Grey wire is hot at all times and fused by fuse #24 in the power distribution center. The Black wire is the ground. The Light Green/Dark Blue wire goes to the Powertrain Control Module which provides ground to the fan relay when cooling fan operation is needed. The Dark Green wire provides switched power to the fan motors.
Using a digital test meter, check for 12 volts on the Grey wire. Check for good ground at the Black wire. If you have good results with those two tests, ground the Light Green/Dark Blue wire at the relay. The fans should start up and run at high speed. Now is a good time to check the current draw on the fans-they should not draw more than 15 amps. If the fans do not run, check the operation of the fan motors by jumpering the Grey wire to the Dark Green wire. If the fans work, the relay is bad.
When replacing the relay, always clean the mounting surface and apply new thermo grease.
To check operation of the PCM, disconnect the connector to the engine coolant temperature sensor and check the Light Green/Dark Blue wire to see if the PCM is switching the ground to the relay. If it does not, check that wire at the PCM connector. If it switches there, you have an open between the PCM and the relay.
Common problems with this vehicle: Poor ground at for the relay, bad relay, bad ground for the engine coolant temp sensor.
Feb 23, 2017 | Chrysler Cars & Trucks
Brooks crompton betts model 809122v vb-b01
Contact manufacturer and request info.
Apr 23, 2012 | Computers & Internet
Replaced old Sta-Rite pool motor with new 1.5 hp Emerson 1081 pool motor. Used exiting 240V wiring. Wired L1 to 120V (black wire), L2 to 120V (red wire), Ground to green ground Screw (green wire). Turned...
Get qualified electricrian to help. I've had the same problems with my pool pump. If you make one little mistake, it could be your last.
Oct 05, 2011 | Pool & Spa
How dou you connect the electical wires I connected them and it throws the breaker
Look at rating plate on motor.
Look for volts, watts, amps.
Figure with Volts x Amps = Watts.
Amps = Watts divided by Volts
1 hp horsepower is 756 Watts.
Lets say you have 120Volt 2hp motor
So 2 horsepower motor draws 1500 Watts
Amps = 1500 Watts divided by 120Volts = 12.5 amps = so you need 120Volt 15 amp breaker with at least 14gauge wire (as long as motor is located within 50 feet of breaker.)
If motor is farther away, then you need 20 amp breaker with 12gauge wire.
Look at circuit breaker rating.
If motor is 240 and breaker is 120, then it will trip breaker.
If motor is 120 and breaker is 240, then it will trip breaker.
If breaker is for 15 amps and motor draws 20 amps then it will trip breaker.
Generally speaking, if motor and breaker are 120V, then black wire goes to black wire; white wire goes to white wire and green wire connects to bare copper wire.
If motor and breaker are 240V, then wire colors can be different. Black-red or Black-white from breaker connect to Black-red or Black-white at motor.
Add a comment. Say the motor rating and color of motor wires. Say the breaker size and color of wires coming from breaker and I will help you wire the device.
Nov 27, 2010 | Northern Industrial Tools Electric Meat...
I have a gmf electric motor and it has 4 wires .. blue brown black and yellow/green .. is this a 3 phase motor and if not how would it be wired into a single phase circut?
No it is a single phase motor the different wire colors are the different speeds brown would be common and then black is high, yellow medium and blue low and green is ground.
Mar 12, 2010 | Heating & Cooling
Have a 3 phase 7.5 HP IR compressor,want to put a 7.5 HP single phase motor on it,how do I wire the starter switch
You will use two of the original three wires. Not knowing if you have a motor starter and how it is wired makes it impossible to give you details.
BE AWARE that a 7.5 HP single phase motor is going to draw a massive starting surge compared to a three phase motor. I assume this is on a 240 volt system as it would NOT be practical to use a motor that size on a 120 volt system.
Expect to require around a 30 to 50 amp single phase feed to the motor.
Dec 20, 2009 | Air Tools & Compressors
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Philips cd player
There are several locations that may be able to help.
  1. Athira Electricals
    Sankar Bldngs, Thakaraparambu
    east fort
    ph: 2468949
  2. Cosmos Electricals
    Power house road
    Ph 2479710
  3. Cynosure Electric Company Ltd
    Pulimoodu
    Ph 2329368
  4. Crompton greaves
    Mettukada
    Ph 2320744
  5. IGA Tech
    Industrial Electricals
    Ph 2557394
Jan 22, 2008 | Philips CDR785 3-Disc CD Recorder
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
