Question about HEWLETT-PACKARD T790 InkJet Plotter Printer
Hp designjet t790 landscape - HEWLETT-PACKARD T790 InkJet Plotter Printer
How to remove the error paper loaded incorrectly:remove paper on hp Designjet T790
Ensure you have the full range of support from HP.
I have Support assistant and HP printer assistant on my desktop. These were downloaded from the HP support website.
Oct 11, 2017 | HP Office Equipment & Supplies
HP DesignJet T790 gives indication clean paper from a way of passing
After all this I hate to ask, are you sure the paper is loaded square on the spindle? I have had some users not seat the paper correctly when loading and that causes issues.
Sep 11, 2016 | HP Designjet T790 Inkjet Large Format...
My HP Designjet T790 report "Error 21.2.:13, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
This is a service station error. One of the more common causes I have come across is a piece of paper or foreign object jammed in the service station. It is located on the right hand side of the carriage. Unplug the plotter. Plug it in and the minute that you hear the print head move, unplug the power. Then open the window, move the head out of the way and look for a foreign object stuck in the service station.
May 15, 2015 | HP Designjet T790 44-In Postscript...
Do you have take apart istructions for an HP Designjet T790
  1. Take the first paper clip and contact the lower two brass rectangles, this fools the device into believing the duplexer is installed, keep the contacts bridged (don't remove your hand or the paper clip until Step 4.) There's no electrocution risk.
  2. Press the "OK" button on the control panel to pretend the paper jam is cleared.
  3. Carefully observe the pair of white gears on the left, if they seem to clutch, stall, skip or freeze then you have paper shards which are causing the jam.
  4. Using a firmer grip or pliers, grip the furthest left rubber roller and rotate in either direction , the gears should rotate with your efforts and look for shards of paper in the gear teeth.
  5. Use the paper clip, toothpick or any appropriate edged tool to clear the shards.
I share a informative links please visit and follow instruction i hope solved your issues.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00441807
Thanks,
HP Printer Support
Jun 23, 2014 | HP Designjet T610 InkJet Printer
How to recovery Hp Designjet T790 24-in hard disk?
jeano: if you don't have the Recovery DVD, get with the Manufacturer of the hp Designjet, they will send it free (in warranty) with instructions. bigAl
Apr 19, 2014 | Misc - MFG CR650BBCB Hp Designjet T790...
Restore factory defaults
You usually need HP Webjetadmin 10.3 to do that.
Dec 16, 2013 | HP "Designjet T790 44"" Large-Format...
Error se 36:01 hp designjet t790
If this error code was caused by a paper jam better could you tell what lead to this erro, unplug the power cable from the printer and clear the blockage. Open and remove the Clean out assembly from the printer and see if you have any particles left inside it. Plug in the power cable again and check if the Error Code has disappeared.
Nov 15, 2013 | Office Equipment & Supplies
Service Manual T790
hi.i have the code but i cant say that here.hp designjet t790 service menu code 09361002314 azad
Mar 17, 2012 | Office Equipment & Supplies
Print orientation
somewhere i believe you have auto rotate enabled in the driver, and it is cancelling your application's landscape setting. Good Luck!
Jul 15, 2008 | HP Designjet 110plus nr InkJet Printer
HEWLETT-PACKARD T790 InkJet Plotter Printer Logo
56 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
