Question about Onkyo Ht-s5400 7.1 Home Theater Speaker System Hts5400
Sound cuts out every minute or two on Onkyo HT-S5400 when attempting to play certain blu-ray discs.
I am having a problem with audio drop outs when playing certain blu-ray discs through the Onkyo HT-S5400 receiver. The player is a Panasonic DMP-BDT210 Integrated-Wi-Fi 3D Blu-ray DVD Player. It is connected via HDMI cable to the Onkyo receiver. I do not have the problem with every disc. The sound drop outs occur every minute or every two minutes and last about 10 seconds each time.
smarthome2
  • 1114 Answers
SOURCE: 1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
Posted on May 23, 2009
  • 5 Answers
SOURCE: What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Posted on Jan 02, 2009
  • 11 Answers
SOURCE: HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Posted on Jan 29, 2009
  • 128 Answers
SOURCE: problems connecting onkyo and panasonic blu-ray
hi look at these two posts
First
second
hope that helps
Posted on Feb 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I cannot get video signal from my Samsung p1590
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
Black and white picture from blu ray player
Run the Blue Ray straight to the TV and see if the picture is still in black and white. If it is you know that your reciever is fine and the problem lies in the player or the TV. If the picture is normal then you probably have a bad HDMI IC that will need to be replaced.
May 09, 2012 | Onkyo TX-SR607 Receiver
I getting onkyo ht s5400 before 10 days. Surrounding sound is faulty, They are not working properly.
If your amplifier is ONLY 10 days old. DO NOT ATTEMPT TO TAMPER AS ONKYO WILL NOT ACCEPT WARRANTY CLAIMS. So please check if the speakers are connected and the mode set to surround, use a DVD with DTH CD and if there is no sound then try to reset- refer manual- if not power off for 6 hours , if faulty then contact service.
Aug 30, 2011 | Audio Players & Recorders
My ONKYO 308 blu-ray player sometimes freezes half way through play back when playing normal (original) DVD discs. It behaves as if the DVD has a sratch. From there it does not want to advance the disc to...
Hello, it might be difficult to find the cause since it only does it on some DVD's. Did these DVD's play OK at one time on the 308? Thank you, Onkyo USA
Jun 01, 2017 | Onkyo BD-SP308 Blu-Ray Player
I have an Onkyo HT-R680. I have noticed after about an hour or more while playing Xbox or PS3 the sound will start to cut in and out. 5 secs of sound, 5 secs no sound. Continually like that untill I shut...
I've been having similar problems. I placed small fan to better circulate air in the closet I keep it in and that has fixed the problem so far. So some sort of thermal overload, I suppose?
Feb 23, 2011 | Onkyo Audio Players & Recorders
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
My onkyo DV BD-507 only play dvd disc, and dosent play blu-ray disc
Sep 25, 2010 | Onkyo DV-BD507 Blu-ray Disc Player, Black
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
No sound for *some* blu ray discs / can't get a menu
Some blu ray disc play fine. Others play the menu music, but when the feature starts, the sound disappears completely. And then others don't play music at all, no sound what do ever.
Feb 05, 2009 | Onkyo TX-DS838 Receiver
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Onkyo Ht-s5400 7.1 Home Theater Speaker System Hts5400 Logo
175 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
