Question about Fuji GA645Zi 35mm SLR Camera
Can you focus closer than 1m for close up work on a Fuji GA64Zi?
Please let me know if there is an accurate method available for close focus on this camera.
  • ray_sturdy Jan 04, 2009
    Yes, I know because I have the instructions which came with the camera. Any more suggestions?
    Scholar:
  • 95 Answers
According to Fuji, the minimum focusing distance on this camera is 1m, so no. Its one of the camera's limitations
Posted on Jan 04, 2009
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
Sep 04, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
By adjusting the diopter on your camera effect the image quality? I guess what I'm trying to say is, will the diopter setting effect how your camera adjusts the focus in auto or manual?
Diopter is for your eye only and does not effect the focus of the camera. By using the 1/2 down method, by pressing the photo taking button half way down, you can set the cameras focus. on some cameras this is shown where it will focus by a red square. If you change the diopter this is like adding by focal lenses for reading a book. and setting the distance your particular eye needs for eye relief. On binoculars this is done with screwing the eyepiece closer or farther away from the other lens. check out online http://en.wikipedia.org/wiki/Eyeglass_prescription this will give you more details of what a diopter is or does. Always know what setting your shooting at as well. for instance if you are on a flower setting or Macro then this is for up close work. But up close doesn't mean too close. Most cameras on Macro need to be 6 inches to 12 inches away. But if you are say 24 inches away it won't focus right so don't try to zoom in, use your optical instead of digital and simply move closer or change the settings on the camera to a different setting or it may be blurry.
Jul 24, 2011 | Cameras
I own a Nikon D5000 and am experiencing issues with the 55x200 lens. When trying to take a picture (on auto mode) of an item that is too close, I am hearing a squeaky noise (like the noise made my a VCR...
The 55-200mm lens does not focus closer than 1.1 meters (3.6 feet). If the subject is too close, then the autofocus tries and fails to focus or keeps trying (and squeaking). Either way, you won't be able to take a picture. In manual focus, you can take a picture but it will be out of focus and blurry.
Every lens has a minimum focus distance, closer than which it will not focus. Some lenses focus closer than others. It's a matter of design; making lenses focus closer makes them larger, heavier, and more expensive.
If you want to take close-ups, you have several options. You can buy close-up adapters that fit onto the front of a lens. You can buy a special close-up lens ("macro" or "micro" lens). You can buy extension tubes to fit between the camera and a lens.
Jul 18, 2011 | Cameras
I would like to know if there is anything I can do tonprevent my battery from dying as I do not have my charger neer by. My camera is a finebpix fujifilm z70. Please help
There are several battery saving techniques that can be addressed the first being using the viewfinder and limiting the use of the LCD as much as possible. Limit the use of the internal flash. I often switch to manual focus during cold weather to save on battery power. On my Fuji FinePix camera the rather odd looking in focus indicator provides a accurate guide for correct focus. It might take a little getting use too as it works like a bar graph with the center being optimum focus and you turn the lens barrel until the graph comes to meet the center line. Took a little before I understood what it was doing. What didn't take long was for me to see the power savings Manual had over the auto focus. Also there is a power off mode that can be set for 2 minute auto off, here is a diagram to show you were it is.
Dec 31, 2010 | Fuji FinePix S7000 Digital Camera
I HAVE A NIKON 60 AND NEED TO KNOW WHAT TYPE OF LENS TO GET
In order to get close to the subject, you need to be able to focus close. If you're using one of the kit lenses, you won't be able to get much closer than a foot or two.
In order of decreasing cost:
  • Special macro lenses are designed to focus closer, as close as a couple of inches, but they cost more.
  • Extension tubes fit between the camera and other lenses, allowing the lens to focus closer.
  • Close-up adapters fit in front of the lens, also allowing closer focus.
One major consideration with any type of close-up photography is lighting. Having the camera close to the subject tends to block out light. Two possible ways around this are: a tripod or other support, and an additional light source such as an external flash unit.
Jul 22, 2010 | Nikon D60 Digital Camera
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
Aug 09, 2009 | Fuji Finepix Z20fd Digital Camera
Hi I bought this camera Fujifilm finepix s10000 fd in order to photograph sharp and clear close up pictures the best way I can. When I press the Menu/ok button = nothing happens. It simply does not...
if your wanting to do macro photography (close up) on the dial on the back, click the left button on the circle and a little flower should pop up on the screen saying "Macro, close up shots" this is for pictures that are closer up then regular and U want them in focus. it takes a few times to get it focused a few times but when it is focused properly, the square in the middle of the screen should be red. if you want really close up, click the button another time and the flower should come up again and it should say "macro close up shots up to 2cm (0.8in). once again once its focused properly the square will be red. you will have to practice because it takes time to learn where its proper focusing points are but i'm sure you will get the hang of it.
Aug 04, 2009 | Fuji FinePix S1000FD Digital Camera
How do you focus closer than 1m for close up work?
look for macro instruction, looks like a flower head
Jan 02, 2009 | Fuji GA645Zi 35mm SLR Camera
Change format of shots from 1M to 2m,3m etc
You can download the manual from the link below: http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S5000Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 01, 2007 | Fuji FinePix S5000 Digital Camera
Auto focus
If you were doing close up- did you switch to Macro? do bare in mind that in close too situations, the focus sensor it looking at something different to the viewfinder[Parallax syndrome]
Jul 13, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji GA645Zi 35mm SLR Camera Logo
132 people viewed this question
Top Fuji Photography Experts
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
