Question about Olympus FE-170 Digital Camera
Fbatteries run out really fast
Fully charged & new batteries run out after taking a only a couple of pictures.
  • Anonymous May 03, 2009
    Batteries take seeral photos and then the red battery appeas saying that the batteries are flat. I have used all sorts of batteries including the super duper rechargeable ones and they all react the same. I am about to throw the camera away and get a new one, a different make and system altogether.
  • 31 Answers
Your camera probably need to be soldered together to make everything fully secured. Jus topen up the camera and use a soldering iron to fix everything or bring it to a shop and they will do it for you.
Posted on Jan 02, 2009
  • popemohamed
    popemohamed Jan 02, 2009
    Also, PLEASE RATE!!!!!!!!!!!!!!
I just bought a tasco trail camera. I set it up by the manual that came with it. It will take a couple of pictures and then it seems to shut off. If I take the batterys out and reinstall them it will work...
Hi.
Are the batteries fully charged? It is recommended that you fully charge the batteries first before you use the camera as the camera can literally eat batteries.
If you have fully charged the batteries and the camera still only allows you to take a few shots then I suggest that you take/send the camera back and have it replaced.
Regards.
Apr 28, 2011 | Cameras
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    Battery depleting way to fast
    first check that your blue tooth is on ..2nd if you have bought a new battery the charged it at least for 7 hour.
    Jun 15, 2010 | Samsung SGH-S5230 Cell Phone
    Battery won't charge on my HP photosmart M407. Batteries are new. What else might be wrong?
    It could be something wrong with the power board. If you have an external charger to charge the batteries. After fully charged tried to take as many pictures as you can. If the battery discharge fast, that mean something is wrong with the power board.
    May 19, 2010 | HP Photosmart M407 Digital Camera
    Camera won't turn on to take pictures~
    This is a common problem related to batteries. Use 2100mA or higer batteries fully charge batteries. This problem occurs when you use alkaline batteries or faulty NiMH batteries. To solve the problem try with new fully charged NiMH batteries.
    May 14, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
    I charged my Duracell 2400 mAh batteries for 15 minutes, and I was able to shoot only 10 pictures with them in my digital camera before they went dead. What is the problem here? I repeated the process with...
    your lucky then,,, they take 16 hourse to fully charge unless you rapid charge them? a nasty thing to do to a new battery? all ways slow charge them first,,
    never fast charge any battery only charge at whats called "the C10 rate!" they live much longer that way,
    in other words slow charge when first charge,,,faster after that! ok,, did you not know you must "form the cells first" before you use them?
    Oct 24, 2009 | Duracell NiMH AA/AAA Battery Charger with...
    The battery is run down every time I come to use the camera. So it seems to bleed out power even when turned off. I have replaced the original battery and the new battery also runs out while sitting turned...
    This is not a common/generic problem for this camera, we need to be a bit more creative into it resolution.
    I am assuming that you have already checked for accidental 'power on' of the camera prior to reporting it. By accidental power on, i mean that as this is one of those semi-pro dslr cameras you need to make sure that the power is turned off before you replace the lens cap as otherwise you can mistakingly leave the camera on while the covered lens will show nothing on the lcd/viewfinder display.
    Check the time it takes for you to charge your battery. It should take a minimum of 5.5 hours to charge the battery fully. If the charging light on the charger turns off before then, continue charging for the next couple of hours. Try using the batteries again. Also, please note that temperature is very important both during usage and charging. As per Sony, the optimum charging temperature is 25 degrees C or 77 degrees F. In colder areas, battery power runs out extremely fast.
    Aug 21, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
    The battery runs out in a couple of minutes
    Try getting a replacement battery, old batterys charge hold depleats over time.
    Apr 12, 2009 | Coby MP-610 MP3 Player
    Can view memory card but wont power up to take pics
    Try using brand new fully charged rechargeable batteries like NiMH or NiCd. Also try viewing though the computer via USB.
    Sep 17, 2006 | Olympus Camedia Stylus 300 Digital Camera
    Problems with Batteries
    Try using brand new fully charged NiMH or NiCd batteries.
    Sep 12, 2005 | Olympus Camedia D-540 Zoom Digital Camera
    Olympus FE-170 Digital Camera Logo
    76 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
