Question about Gateway DX4200-09 PC Desktop
Dx4400 boots to gateway logo and stays there for a long time
Boots directly to Gateway logo normally but hangs up there for sometimes 5 to 10 minutes. It then boots into windows.
    Novelist:
  • 178 Answers
What windows do you have? what anti-virus? then check your
system tools program in Start/Accessories/, run Disk Cleanup
after system up. wait till finished then run Disk Fragmentor. If you
have a anti-malware program or anitvirus program run thoughs one after the other, cleanup first.
You may need to clean up your registry too. Make sure you have not downloaded any third party PC Cleaners, or programs which claim to keep pc running fast. these are usually bad and hog system resources. After doing what i have suggested, download CCleaner from Cnet.downloads web site. do a search to find it. after downloading CCleaner(free version), run the two top jobs on left of box. 1) Cleaner(broom icon), then after finished 2) Registry(stacked boxes icon). if 2) asks you if you want to save backup, say 'NO'. this will clean your harddrive of garbage and clean the PCs registry. These things can really slow you down.
Please DO NOT run anything else in CCLEANER. Only experienced computer users should change or runs any other program in it. Much harm could be done if YOU DO. Hope this helps.
Posted on May 17, 2014
micromend
  • 748 Answers
SOURCE: Gateway GT5228 not loading Video
Checked memory?
Posted on Mar 27, 2009
KingDWS
  • 1606 Answers
SOURCE: screen stuck on black with gateway logo
That indicates a hardware problem. From your description I would check the cpu or suspect it as being the problem. It can be a ram problem as well.
Posted on Aug 21, 2009
  • 191 Answers
SOURCE: Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Posted on Oct 05, 2009
huffman49
  • 235 Answers
SOURCE: my gateway 510x keeps shutting itself off.
sounds like your processor fan shut down and now your processor itself shuts off when it begins to over heat replace fan asap and don't keep trying to turn it on because you'll burn it out
Posted on Apr 02, 2010
murmerjoy
  • 805 Answers
SOURCE: Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Posted on Apr 08, 2010
My laptop boots to the Gateway logo then nothing happens.
Try holding the F2 or DEL key down when you start it, This should get a screen that shows the BIOS, Look to see if any hard drives are listed. If the hard drive failed, it may cause this issue.
Feb 05, 2016 | Gateway Computers & Internet
When I turn my computer on it boots up just fine & monitor works. At some point, sometimes a few minutes, sometimes a few hours the monitor will go black and I get a no signal message. The system is...
would appear the system is in standby mode you could disable this
in windows 7 or vista go to
start
control panel
power options
choose when to turn display off
Sep 05, 2011 | Gateway Computers & Internet
Gateway Initial Boot Up slow Before Windows
isnt there a quik boot option in the bios?,look at your system info in windows,rt.click my computer and hit properties,is your processor speed correct,and your ram memory all there.?should be a number divisible by 64,if its not and your missing 10 or 15 meg. one of your ram sticks is loose or failing,pop them out and reseat them,seems to help some of the time,hope this helps ,let me know more details
Sep 08, 2009 | Gateway 450SX4 Notebook
Gateway freeze randomly it just screen freeze
If you can, download Combofix, Vundofix, smitfraudfix, and malewarebytes.
Boot the computer in Safemode, and then run each program, one at a time of course.
If this doesn't fix the problem, then it will at least verify that it's not a virus related issue.
Jul 05, 2009 | Gateway MD2601u Notebook
Boots to desktop stays on for about a minute or two then shutsdow
Sounds like the processor is overheating. Check to make sure that the processor fan is running and that the heat snyc is secure.
Feb 09, 2009 | Gateway GT5242E PC Desktop
Problem logging on to Gateway profile 3
it sounds like it is booting to a network... unless this is normal you need to change the order the computer boots.... f12 i believe is the right key to tap on as it is booting up.... have it boot directly to the hard drive... unless of course you require it to boot to a network
Jan 02, 2009 | Gateway Profile 3 PC Desktop
Gateway Tablet, BSOD unmountable_boot_volume
you have to go to gateway and download the driver for the SATA controller then save it to floppy or cd then hit F6 durning install then it will ask you for the driver. This Tablet will not see a non-gateway cd if you have the one that came with the tablet then you are good, but if not you will need to do this for the current drive or if yo upgrade to newer drive. Hope this get you started, I had this same problem and I thought it was my motherboard was bad because it would not see the hard drive during installation. This fixed my issue with the drive not being seen during installation of the OS.
Mar 28, 2008 | Tablets & eReaders
Gateway DX4200-09 PC Desktop Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
