Question about Sewing Machines
Top thread pulls and breaks while sewing.
The top thread keeps breaking. I have adjusted the tension, but it makes no difference.
  • Sewing Machines Master
  • 7,365 Answers
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Posted on Oct 24, 2012
SOURCE: Thread breaking
Well, I have owned the Janome 1600DP with the Gracie Frame for 3 years now and have only successfully quilting 3 quilts. Its very intimidating how easily the thread breaks!!!! Add hot flashes with the frustration and I've almost given up. Today, I think I have found something. I cleaned the bobbin case, cleaned between the discs, put in a new needle (using the one recommended) but I put the spool of thread in a coffee cup located at the non-sewing end of the machine, sitting it on the Gracie Frame. Then the thread is through the metal eye ring that came with the frame. All the rest of the threading is per the Janome instructions. So far, so good. There you have it but if I had to purchase a sewing machine again for quilting quilts, it would NOT be a Janome!!!
Posted on Oct 04, 2008
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
Zenqi
  • 208 Answers
SOURCE: the top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Posted on Jun 17, 2009
  • 46 Answers
SOURCE: Top thread keeps breaking on ESe2.
Many things can inter fear with the thread and cause it to break. A common problem is the thread getting wrapped around the top tension rollers on that machine. You can take off the "face cover" (side cover on the left) and look from the side and see if the 2 little rollers have thread wrapped around or underneath them. Start there.
Posted on Jul 25, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
Singer 2273
Install a brand new needle (make sure it is compatible with the thread and fabric). Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the top tension to the midway point and retest your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
AVOID old or bargain bin thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
Sewing Machine Thread Keeps Breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Why is my thread breaking
Mar 20, 2018 | Singer Sewing Machines
Why does top thread keep breaking?
Sounds like your tensions, both upper and lower are out of whack. Easily fixed if so...google a vidyfor your make/model machine on adjusting both upper and lower tensions.
Jun 18, 2017 | Sewing Machines
My bobbin and thread are constantly breaking. I have the correct thread to needle, but I don't even get one stitch before both break. Tension is on auto; should it be less or more?
is the needle in the holder the correct way ( groove in the needle facing the thread )
Is the needle eye the correct size for the thread in use
remove it from auto tension setting and adjust it your self
make sure that the top thread is between the tension plates and not around the thread behind the plates
the thread tension is close to correct when you need a bit of a pull to pull it along to the needle
is the method of threading to the needle correct as any areas where the thread reverses direction will cause it to break
what do mean that the bobbin is constantly breaking or is it the bobbin thread that is breaking
have you got the thread down the case slot and under the flat spring correctly
the bobbin has to be inserted into the case in such a manner that when the thread is pulled , it flows down the slot freely as the bobbin turns
if the direction is wrong , the thread has to move across the sharp edge of the slot and will cut easily
Dec 21, 2015 | Brother Sewing Machines
How do I set a straight stitch? What is causing the top thread to break?
You do not say which machine you have. As for a straight stitch, make sure the needle is central and not in zig zag mode.
The thread can break for several reasons, such as. Incorrect tension.
:Wrong thread for the material.
: Thread in bobbin different from the top thread.
:Old thread.
: Not threaded correctly.
: Needle not inserted correctly, or incorrect needle.or the thread could be wound around the spool holder pin,
Try removing the spool and turn it around.
Hope this helps.
Mar 02, 2015 | Sewing Machines
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
The top thread breaks
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
THE COTTON KEEPS ON BREAKING EACH TIME I WANT TO SEW
8. try a different thead
9. try adjusting the top thread tension
Dec 20, 2012 | Sewing Machines
THE COTTON KEEPS ON BREAKING EACH TIME I WANT O SEW WITH MY YAMATA FY940
8. try a different thread
9. try adjusting the top thread tension--to a lesser number or letter
use your manual to guide you through tension adjusting
Top thread keeps snapping on consew 230b
Top thread snapping. Do you have an idea of there it is breaking?
First I would check the needle throat plate and needle. If you have stab marks on your needle plate, examine it closely for a crack. (get out the magnifying glass or jewelers loop) I recently fixed a problem I had with an old singer that kept breaking the top thread by replacing the needle plate. The old needle plate was so damaged it had actually made a knife edge which consistently cut the thread right at that location.
Change your needle and make sure it is the proper size for your thread. Too narrow of an eye can shred the thread causing it to break.
Next, check anything along your threading process that could be catching or snagging the thread. A worn or chipped thread guide can be a real problem.
Also make sure your thread hasn't dropped down below your thread cones and wrapped around the thread spindle. This would cause extra tension that might not be readily apparent.
Good luck
Aug 15, 2012 | Consew Sewing Machines
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
195 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
