Question about La Crosse Technology La Crosse C86234 Wireless Weather Station
Wind sensor not transmitting a signal - La Crosse Technology La Crosse C86234 Wireless Weather Station
Can't get a temperature reading on my Springfield 91756 thermometer even after changing batteries. Just get - - -.
The batteries in the outdoor unit have to be changed first and time allowed for it to begin transmitting. If you are in a very cold location, the batteries may may decline in efficiency to a point where the outdoor unit can't transmit. In this case, you may find that the temperature reading returns in warmer weather.
Feb 23, 2015 | Springfield 91751 Digital Rf Weather...
WHAT IS ICP
An integrated circuit piezoelectric sensor or ICP sensor is a device used to measure dynamic pressure, force, strain, or acceleration. It contains a sensing element made of a piezoelectric material, which converts mechanical strain into an electrical signal, and anelectronic circuit to amplify this signal and transmit it to an external device.
ICP is an abbreviation of "integrated circuit piezoelectric", and is a registered trademark (no. 1,603,466 in the USA) of PCB Group, Inc., parent company of PCB Piezotronics.[1] There is a similar non-proprietary standard called IEPE, which stands for "integrated electronics piezoelectric."[2]
In an ICP sensor, the built-in electronics convert the high-impedance charge signal that is generated by the piezoelectric sensing element into a usable low-impedance voltage signal that can be readily transmitted, over ordinary two-wire or coaxial cables, to any voltage readout or recording device. The low-impedance signal can be transmitted through long cables and used in dirty field or factory environments with little degradation. In addition to providing crucial impedance conversion, ICP sensor circuitry can also include other signal conditioning features, such as gain, filtering, and self-test features.
The electronics within ICP accelerometers require excitation power from a constant-current regulated, DC voltage source. This power source is sometimes built into vibration meters, FFT analyzers, and vibration data collectors. A separate signal conditioner is required when none is built into the readout. In addition to providing the required excitation, power supplies may also incorporate additional signal conditioning, such as gain, filtering, buffering, and overload indication
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Aug 14, 2014 | Cars & Trucks
Check engine light sensor
DTC P2138: Accelerator Pedal Position (APP) Sensor A/B (Throttle Position Sensor D/E) Incorrect Voltage Correlation.
Accelerator pedal position (APP) sensor A and accelerator pedal position (APP) sensor B are potentiometers, and they are installed in the engine compartment.
The APP sensors A and B are operated via the throttle cable to determine the accelerator opening value when the driver presses the accelerator pedal. The accelerator pedal opening value is converted to a signal in APP sensors A and B and transmitted to the engine control module (ECM)/powertrain control module (PCM) to compute the target position. The target position signal is then transmitted to the throttle actuator control module.
APP sensor A is for the primary control, and APP sensor B is a back-up of APP sensor A in case it malfunctions. Both sensors compare their output voltage to each other for malfunction detection.
When the voltage difference of APP sensor B is out of a fixed range for a set period of time, the ECM/PCM detects a malfunction, and a DTC is stored.
Sep 15, 2013 | 2007 Honda Accord Sedan
I have a 1200 sportster i have no power to my odometer the lights on it dont work its not showing the milage and the fuses have been replaced what should i do?
It could be the vehicle speed sensor, the ECM or the TSM/TSSM.
The vehicle speed sensor (VSS) is powered and monitored
by the Electronic Control Module (ECM). The ECM processes
the vehicle speed signal and transmits this signal to the turn
signal module/turn signal security module (TSM/TSSM) and
speedometer through serial data.
NOTE
The vehicle speed sensor cannot be repaired. Replace the
unit if it fails.
Jun 10, 2012 | 2005 Harley Davidson XL 1200 C Sportster...
Trubleshooting p0502 honda element
P0502 is a Vehicle speed sensor issue:
P0502 Description The vehicle speed sensor outputs a 4 pulse signal for every revolution of the rotor shaft, which is rotated by the transmission output shaft via the driven gear. After this signal is converted into a more precise rectangular waveform by the waveform shaping circuit inside the combination meter, it is then transmitted to the ECM. The ECM determines the vehicle speed based on the frequency of these pulse signals.
speed_sensor.gif Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Speedometer may not work properly
- Transmission shifting problem Possible Causes - Vehicle speed sensor harness or connectors is open or shorted
- Combination meter
- Faulty ECM.
Jul 13, 2011 | 2003 Honda Element
Crankshaft Position Sensor need power or not?
Indirectly yes, it is a sensor, and while it is not powered as such, it does transmit an electrical signal. Trying to put 12 v straight to it might blow a whole lot of expensive components in various computers etc.
Jan 30, 2011 | Ford Transit Connect Cars & Trucks
Where is located tps in altima 97
1997 Nissan/Datsun Altima 2.4L SFI DOHC 4cyl: the Throttle Position (TP) sensor is a potentiometer. It is mounted on the side of the throttle body and is connected to the throttle plate shaft. The sensor monitors throttle plate movement and position, and transmits an appropriate electrical signal to the ECM. These signals are used by the ECM to adjust the air/fuel mixture and spark timing according to engine load. The TP sensor is adjustable on some models.
Automatic transaxle/transmission TP sensors contain position switches. These switches provide a signal to the ECM when the engine is at idle and wide open throttle.
Hope helps (remmeber to rate and comment this).
Sep 27, 2010 | 1997 Nissan.5 Altima
What cause the O/d light blink
it's usually because you have a bad VSS, Vehicle Speed Sesnor. It sends a signal from the trans to the speedo and engine computer. Usually speedo stops working too.
Vehicle Speed Sensor (VSS) The vehicle speed sensor (VSS) (9E731) is a magnetic pickup that sends a signal to the powertrain control module (PCM) (12A650) . This VSS signal transmits vehicle speed to the powertrain control module .
Nov 10, 2009 | 1998 Ford Windstar
Tv not taking remote signal
First check if the remote works. This can be done by using a digital camera or cell phone camera. Point the remote at the camera lens and start pressing buttons on the remote. If you see a blinking light on the LCD preview screen of the camera, then you know the remote is transmitting.
If the remote is not transmitting, replace the batteries. If this still does not work, you should get a new remote.
If the remote is properly transmitting, then the issue is going to be with the TV. It depends on the type of TV you have but usually is either the IR sensor board or the main board which are in charge of receiving and decoding the signal from the remote.
Oct 13, 2009 | Televison & Video
Loss of power
I have always assumed this has to do with the level of the signal coming in.
I have had these headphones for a few years, getting them at a discount outlet for cheap, and have been quite pleased with them.
The light on the front indicates 3 things.
1) no light = not transmitting and not charging
2) green light = transmitting
3) red light = charging
When there is sufficient signal to transmit, the green light comes on.
If you are getting the signal from a Stereo, the line output may NOT be enough to keep the transmission on.
There seems to be a sensor, that figures out if htere is an incoming signal to transmit. I have toyed with the idea of locating that and disabling, so it would always transmit what is incoming, even if a low signal! But I don't have the know how.
As is, I use the headphones with my PC and generally it finds the signal strong enough to continue to transmit.
.. Thanks... Andrew
PS..The toughest thing about these haedphones, is going to be finding NiCad batteries to keep them working. If you go in the store these days, you can find lots of NiMetal Hydride, and NiCad are gone from the shelves!
Jun 13, 2008 | RCA WHP150C Consumer Headphones
La Crosse Technology La Crosse C86234 Wireless Weather Station Logo
99 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
ka4iup
ka4iup
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
