Question about Zyxel ZyWALL 2WG (91009035003B) Firewall
Split tunneling zywall - Zyxel ZyWALL 2WG (91009035003B) Firewall
I have comcast cisco cable that is working fine but when I hook up vonage I get no internet why?
More than likely you need to enable split tunneling on vpn settings in router. If Vonage uses a vpn tunnel like other VOIP services do, then it is probably encrypting all traffic on your Internet/WAN interface. With split tunneling enabled it will only encrypt traffic to and from Vonage. I'm making a few assumptions here, but it should be worth a check.
Jul 23, 2014 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Zywall usg 50 won't VPN to 3Com officeconnect
Check the system log of the devices. The log usually can tell you why the VPN is not working.
Apr 02, 2014 | Zyxel ZYWALL USG 50 SEC-GTW 5 VPN TUNNEL -...
Zywall l2tp ipsec
There are many root causes can make the VPN connection not stable. You should try to rule out the possibility that the outdated firmware cause the issue first. Contact zyxel tech support after you update the firmware.
Feb 19, 2014 | Zyxel ZYWALL USG 50 SEC-GTW 5 VPN TUNNEL -...
ASA VPN setup
this has been nicely explained here:
http://www.computerfreetips.com/Cisco_router_tips/ASA-VPN-tunnel.html
Feb 23, 2012 | Cisco ASA Computers & Internet
I want to block ultrasurf using zywall 2
Open App patrol, search for UltraSurf and block it.
Mar 17, 2011 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
I lost the password, and i can not access the zywall 10. How can i reset the zywall to the default configuration?
you need to use the reset button on the back of the device: it is quite small, so you need to use a needle or a small sharp object to press it. You can find it under the label "Reset" on the back of your router.
Hope it helped,
Franz
Mar 01, 2011 | Zyxel ZyWALL 10 Router
My dad is death and I don't now the password ov ZyWALL 2 plus..please help me... im ITALIAN
Hello there,
Im sorry for your father, by the way if you forget / lost your password(cannot access the web configurator you will need to reload the factory-default configuration file or use the RESET button on the back of the ZyWALL. Uploading this configuration file replaces the current configuration file with the factory-dafault configuration file. This means that you will lose all configurations that you had previously and the speed of the console port will be reset to the default of 9600bps with 8 data bit, no parity, one stop bit and flow control set to none. The password will be reset to 1234, also.
The procedure to use the reset button
Make sure the SYS LED is on ( not blinking) before you begin this procedure.
  1. Press the RESET button for 10 seconds, and then release it. The ZyWALL restarts with the defaults restored. Otherwise, go to step2.
  2. Turn the ZyWALL off.
  3. While pressing the RESET button, turn the ZyWALL on.
  4. Continue to hold the RESET button. The ZyWALL restarts with defaults restored.
  5. Release the RESET button and wait for the ZyWALL to finish restarting.
Hope it help and have a nice day,
regards
Apr 15, 2010 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
Can't access network folder after connect thru vpn
if you connect through vpn and your network folder is in your local network, you cannot access the network folder because you are virtually connected to an external network other than your local network. because of this you are actually trying to find your local network folder that is not present on that external network. you may need to disconnect your vpn before you access the network folder in your local network
Nov 06, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Port 80 forwarding
use hidemyass.com as a home page surth from hear
Jan 24, 2009 | Zyxel ZyWALL 2 Firewall
Zyxel ZyWALL 2WG (91009035003B) Firewall Logo
94 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
