Question about General Electric WHDVH660H Front Load Washer
Trouble with girlfriends ge model whdvh660hbb, supposedly the only thing wrong was a hole in the door boot, replaced that and now cannot get the washer to fill. checked valve screens, there was no blockage, changed valves, still cant get it to fill, replaced control panel, yep still no fill. Any suggestions on what to check next?
4 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: My washer wont spin at all, it will fill and drain fine anyone have suggestions?
hello mam if your machine is not spinning then its not the problem of solenoid problem will; be in the timer.and for your knowledge solenoid functions as a control valve for the water flow.
Posted on Sep 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: need to check fill valves and would like
The fill valve is directly where your hoses attach to the unit.
CLICK HERE to see the valve.
#136 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Feb 21, 2010
richroth
  • 9472 Answers
SOURCE: Washer continues to fill but
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Jan 24, 2011
GE Model PSIC3RGXBV. Inside freezer at top of ice chute, frost builds up. Returns after wiping. Happens on Humid and non-humid days. Empty nesters so doors are closed quickly. All vents inside clear.
the model number didn't come up,but if you have an air leak most likely it's gonna be the ice chute door itself not fully closing,you can get paper towels,and stuff them into the chute hole for a couple of days to see if that's the problem,another thing is open the door and put a light in front of the chute door and look down the hole,if you see light then the door isn't sealing or check the door gasket for any tears
Nov 01, 2017 | GE Refrigerators
Whdvh660hbb ge adora
first unplug the machine
you have a problem with your motor if it can be striped down then you need to change the com (centre bit ) unit and brushes
Jan 09, 2014 | Washing Machines
I have a GE Washer (model # WWA5669MAL). The pump
That is supposed to be weep hole. If water is pouring out then that is a sure sign of a worn out old school GE pump. The good news it that is an easy pump to replace. the hardest part is replacing the drive boot from pump to motor. Nothing to it 0895584.gif
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
GE door boot gasket material?
Best way to remedy your problem is to replace boot. The boot moves and stretches quite a bit. Patch would hold up
Nov 07, 2017 | GE WCVH6260FWW
Torn rubber boot
for model # wsxh208a the part is
WH45X10062 - KIT-BELLOWS & MTG SPRING
should be able to change through bottom access panel and door hole.
make sure to pull clothes gently straight out of the unit and not at an angle across the rubber boot, it tears really easy..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | GE WSXH208A Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
How to change a GE dishwasher door seal
I had the same exact problem TWICE....second time I'm replacing the dishwasher. There are two rubber boots at the bottom of the door that just sit and the door seal is supposed to seat into these rubber boots but if you take out the boot you will see that it is misshapen and therefore leaking. These boots cost about $10 dollars apiece from GE on line. I replaced them once and same problem. I was going to replace the gasket that runs around the door but it costs $50 and I'm not SURE it will fix the problem. I'm on my way right now to buy a new dishwasher....they're not that expensive compared to pumping money into something that you don't know if it will work. Good Luck.
Nov 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Jul 21, 2008 | GE WSXH208A Front Load Washer
General Electric WHDVH660H Front Load Washer Logo
61 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
