Question about La Crosse Technology La Crosse C86234 Wireless Weather Station
Wind sensor not working - La Crosse Technology La Crosse C86234 Wireless Weather Station
  • Freeman Rosebrooks Oct 26, 2012
    I have tried resetting the system by removing the batteries and then applied the start up for the solar wind sensor and it still is not transmitting a siganal to the wireless display..
  • Tim Rubel
    Tim Rubel Jul 06, 2015
    We are having the same issue. How did you get this resolved?
    New Friend:
Posted on Jul 06, 2015
Wind sensor doesn't work
Test all wires for continuity. 90.8 % of problems are caused by faulty wiring.
Aug 13, 2017 | dr. Tech WA-1080PC-T Solar Wireless Home...
Tip
Caterpillar Fault Codes
CID code Name
1 Injector? 1
2 Injector, cylinder number 2
3 Injector number 3
4 Injector number 4
5 Injector, cylinder number 5
6 Injector, cylinder number 6
7 Injector number 7
8 Injector number 8
9 Injector number 9
10 Injector number 10
11 Injector number 11
12 Injector number 12
13 Injector number 13
14 Injector number 14
15 Injector number 15
16 Injector number 16
17 The fuel shut-off valve
18 The fuel control valve
19 Bypass valve accelerator
20 Device change timing of fuel injection
21 Position Sensor Engine
22 Sensor fuel injection advance
23 Drive Racks
24 position sensor rail
27 is a variable geometry turbocharger number 1
28 Drive with variable geometry turbocharger number 2
41 Power ECU (electronic control unit) 8 V DC
42 Valve inclusion nozzles
70 contact with the parking sensor
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor pnevmozapuska
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
96 Fuel level sensor
98 Oil level sensor in the engine
99 The differential pressure sensor on the engine oil filter
100 Oil Pressure Switch Engine
101 pressure sensor crankcase gases
102 turbo pressure sensor
104 Oil pressure turbocharger
105 temperature sensor intake manifold
106 sensor input air pressure
Pressure sensor 109 of coolant downstream of the engine
110 Coolant Temperature Sensor Engine
111 level sensor, engine coolant
The differential pressure sensor 112 to filter engine coolant
124 gearbox oil level
126 differential pressure sensor on the oil filter transmission
127 Oil Pressure Switch gearbox
138 Mode Switch low traction
139 Solenoid tip ago
140 Solenoid tip forward
141 Eco Mode Switch
142 position sensor door to clean the radiator
143 contact pressure sensor control unit neutral
144 horn relay reverse
145 power supply circuit 12
146 Mode Switch hitch
147 pressure sensor lock-up clutch
148 pressure sensor in the hydraulic stroke
149 Three-way solenoid stabilization system of the implement when driving
150 Speed Sensor trambovatelya
151 Solenoid trambovatelya
152 diagnostic lamp control systems course
153 speed sensor right drive motor
154 RPM Sensor left actuator motor
155 solenoid switching stroke
156 Solenoid right turn in reverse (electronic display)
157 Solenoid left turn in reverse (electronic display)
158 Solenoid right turn forward direction (electronic display)
159 Solenoid left turn forward direction (electronic display)
160 Relay working equipment paver
161 brake sensor (chassis) pedal
162 Sensor Steering Wheel
The steering angle sensor 163 rotation
164 Pressure Sensor inclusion nozzles
167 Sensor charging voltage of the alternator
168 Electric system
171 of the ambient air temperature sensor
172 temperature sensor in the intake manifold
174 Fuel temperature sensor
175 Temperature Sensor Engine oil
177 oil temperature sensor Gearbox
190 RPM Sensor engine crankshaft
191 sensor output speed gearbox
248 data channel of Caterpillar
249 data channel J1922 SAE (Society of Automotive Engineers)
250 data channel J1708 / J1587 SAE (Society of Automotive Engineers)
Block 252 calibration
253 Personal chip control unit
254 electronic control unit
256 Map adjusting engine performance
257 Level detonation
258 sensor crank angle
259 set via software point fuel injection
260 oxygen sensor in the exhaust gas
261 the fuel injection timing calibration
262 circuit sensor supply 5 V
The power circuit 263 digital sensors (8 or 12)
264 pedal revolutions reduction
265 Input circuit stopping the engine, user-defined
266 Input circuit dry scroll engine (without fuel injection)
267 Chain input remote control signal Safe Stop engine
268 Error programmed parameter
269 circuit sensor supply
Code 270 cable computerized monitoring system (CMS)
271 Sound the alarm
272 sensor has exceeded the allowable turbo
273 pressure sensor at the outlet of the turbocharger
274 atmospheric pressure sensor
275 pressure sensor at the entrance of the right turbocharger
Pressure transducer 276 at the input of the left turbocharger
277 sensor calibration injection timing
278 The indicator light turn on the automatic control of engine speed (AESC)
279 coolant temperature in the intercooler front section
280 temperature sensor gear
281 The indicator light necessary Engine
282 Light indicator exceeding the permissible engine speed
283 Indicator Light air filter
284 Radio on EMS (electronic control system) (the signal of the engine)
285 overheating indicator light, engine coolant
286 Indicator light low oil pressure
287 Miniature digital output? 7
288 Miniature digital output? 8
289 Fuel pressure - before the fuel filter
290 pressure sensor in the pump drive engine cooling fan
The solenoid 291 engine cooling fan
292 solenoid hydraulic oil cooling fan
293 power analog output? 3
294 power analog output? 4
The control unit 295 hydraulic excavator heavy-duty
296 gearbox control unit
297 all-wheel drive system control
298 The probe brake pedal
299 position sensor gear lever
300 The primary windings of ignition coils
301 The primary winding of the ignition coil? 1
302 The primary winding of the ignition coil? 2
303 The primary winding of the ignition coil? 3
304 The primary winding of the ignition coil? 4
305 The primary winding of the ignition coil? 5
306 The primary winding of the ignition coil? 6
307 The primary winding of the ignition coil? 7
308 The primary winding of the ignition coil? 8
309 The primary winding of the ignition coil? 9
310 The primary winding of the ignition coil? 10
311 The primary winding of the ignition coil? 11
312 The primary winding of the ignition coil? 12
313 The primary winding of the ignition coil? 13
314 The primary winding of the ignition coil? 14
315 The primary winding of the ignition coil? 15
316 The primary winding of the ignition coil? 16
317 load cell
318 Right knock sensor
319 Left knock sensor
320 RPM Sensor / injection timing
321 Key switch reset / diagnostic confirmation
322 engine stop switch
323 The indicator light engine stop
324 Alarm lamp
325 detonation caused by the ignition system
Detonation System 326
327 Wrong number of knock sensors
328 Wrong number of cylinders of the engine
329 Error Link
330 Login with contact sensor propane content
331 Ignition Switch
332 keyboard switch
333 switch alarm
334 Reserve output
335 solenoid screw scraper
336 switch engine control
337 Remote Switch emergency stop
338 Relay pre-lube pump motor
339 contact pressure transducer pre-lube the engine
340 solenoid shut-off air
The solenoid 341? 4 warm-hydraulic distributor
342 Auxiliary speed sensor engine crankshaft
343 injector NOx catalyst in the exhaust gas
344 Relay injection pump converter of nitrogen oxides in exhaust gases
Pressure sensor 345 of the injection NOx catalyst in the exhaust gas
346 Relay stabilization system of the implement when driving
347 solenoid feed control (working volume) motor hydrostatic transmission
348 lock switch gearbox
Solenoid 349 gearbox synchronization
350 position sensor rod lift
351 position sensor rod misalignment
352 Sensor lift lever (in the cockpit)
353 sensor lever skew (in the cockpit)
The solenoid 354? 1 lift
The solenoid 355? 1 lowering
The solenoid 356? 1 unloading
357 Solenoid No. 1 return
358 Drive pressurization of the control loop hydraulic system work equipment
359 solenoid locking lifting
360 solenoid lock lowering
The electromagnet 361 tilt lock to download
362 solenoid control the fan speed of the engine
363 Drive stabilization system of the implement when driving
364 pressure sensor piston cavity lift cylinder
365 switch for limiter
366 contact gauge semiautomatic recess
367 Switch stabilization system of the implement when driving
368 switch, automatic / manual mode transmission
369 Login with shift indicator on the gearbox
370 Solenoid floating position arrows
Solenoid 371 beep
372 solenoid opening bucket (for excavator shovel)
373 solenoid closing bucket trucks through the hinged bottom (for excavator shovel)
374 Solenoid swing brake
375 Solenoid swing brake
376 Warning stroke
377-way solenoid brake
378 solenoid automatic lubrication system of the machine
379 Pressure Sensor automatic machine lubrication
380 contact pressure transducer modulation shift gearbox
381 Contact neutral position sensor lift lever (in the cockpit)
382 lever position sensor coupling
383 position sensor coupling
384 shifter
385 contact sensor neutral position tilt (in the cockpit)
386 solenoid lifting hitch
387 Solenoid lowering hitch
388 Contact line solenoid coupling
389 The probe neutral auxiliary lever
The solenoid 390 controlling the flow of hydraulic oil through the forward clutch
The solenoid 391 controlling the flow of hydraulic oil through the reversing
392 solenoid oil supply
The solenoid 393 to drive the front wheels
The solenoid 394 controlling the flow of oil through the drive motor
395 solenoid switch actuator pressure of the front wheel
396 Light on lamp-wheel drive (AWD)
397 contact pressure transducer feed pump
398 pressure sensor in the front wheel drive
399 sensor to the control lever-wheel drive (AWD)
400 The secondary windings of ignition coils
More Fault Codes HERE Caterpillar DTC
on Dec 20, 2016 | Cars & Trucks
Manual
Go to the Raymarine.com website, they have manuals for their products even ones that have been discontinued.
May 10, 2013 | Raymarine ST40 Wind System Rotavecta...
Ws 2800 rain not displayed
I tried this and it worked fine
FACTORY RESTART:
A Factory Reset will erase the connection between the Display and the Thermo-hygro sensor and allow a fresh connection to be re-established. It is recommended to have the display and all sensors 5-10 feet apart for this restart.
ENTER PROGRAM MENU
Press and hold the SET button until you enter the program menu. Press and release the SET button until you see 'rES oFF' flashing.
FACTORY RESET ON
Use the UP ARROW key or DOWN ARROW key to turn rES on.
CONFIRM & COUNTDOWN
Press the SET key to confirm and a countdown timer will begin counting down from 127. When the timer displays dOnE, you must remove the batteries from the display for 10 minutes
REMOVE BATTERIES FROM THERMOHYGRO AND RAIN
While the batteries are out of the display, also remove the batteries from the Thermo-hygro sensor and the Rain sensor. Wait 15 minutes.
GENTLY KEY THE WIND SENSOR
Gently key the wind sensor one time to activate the sensor.
INSTALL BATTERIES INTO THERMOHYGO AND RAIN
Insert fresh alkaline batteries into the Thermohygro sensor and Rain sensor make sure to check polarity with the markings on the battery cover and inside the battery compartment. Wait 2 minutes.
INSTALL BATTERIES INTO DISPLAY: Insert fresh alkaline batteries into the Display. Make sure to check polarity with the markings inside the battery compartment
15 MINUTES: Wait 15 minutes for the outdoor weather data to display. If the outdoor data displays dashes after waiting for 15 minutes, repeat the steps of restart.
AZ Road Runner
Sep 15, 2012 | Lacrosse La Crosse WS-2800 Series Wind Cup...
I have a sensor that stays on all night when the
Your motion detector is based on infrared or heat sensing technology. Moving air or wind will make your unit more sensitive to false alarming. Here are a few things for you to check: 1) make sure your unit is sealed. Any holes or openings in the unit's casing will affect operation. 2) you may need to readjust the unit's sensitivity. There may be an adjustment pod or jumper inside the detector to reduce sensitivity. 3) make sure the unit is mounted securely. If the wind causes the detector to move, even slightly, this could be the cause of your problem.
Jan 19, 2010 | Heath Zenith 270 Degree Replacement Motion...
Paperfeed problem. Paper is grabbed but winds up
Try to uninstall and reinstall your printer.
Perform a hard reset to your printer.
Clean your printer for dust that may cause sensor problem.
Replace your printers sensor assembly.
Sep 26, 2009 | Lexmark E232 Laser Printer
Washer will not spin LG Washer WM1832CW
1. Open back of the washing machine and control panel. Locate two wire harness coming out of main motor and main board. Check the wires for any cuts and harnesses for any corrosion. Fix the cuts and sand the corrosion to fix the issue.
2. Check the windings on the motor by pulling 3-wire connector from main board. Check resistance between each of 3 pairs using multi meter. The resistance should be 8-15 ohms. If one or more pair has no resistance reading then the winding is burned. Replace the rotor winding.
Rotor windings can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1266809&PartID=1266809
3. If windings are fine then the hall sensor or speed sensor or motor sensor or sensor assembly needs to be replaced. The hall sensor sits on the inside of the rotor winding. Hall sensor has 4 wire connector attached. To remove the hall sensor: Open the outrunner or magnetic rotor from the motor first. Remove a big bolt at the center of the motor by holding the magnetic rotor. Once bolt is removed, the magnetic rotor can be removed by simply pulling it straight out. You may have to wiggle it a bit. Now remove a screw holding a wire going to hall sensor towrds bottom left of the winding. Now remove six inside bolts holding rotor windings to the drum body. The rotor windings are heavy so be careful while removing the bolts. Remove two wire connectors from the rotor windings and pull out the windings. Lay the rotor windings flat facing connector side up. Remove the hall sensor by praying out tabs.
Hall sensor can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1268238&PartID=1268238
Jul 14, 2009 | Washing Machines
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
May 08, 2009 | Polar Cadence Sensor W.I.N.D
Speedometer, odometer, cruse control & tranny overstopped working
If it has antilock brakes, the sensor is on the top of the rear differential. This sensor usually drives the speedometer. check the sensor for an open in its windings and also the wire that connects to it for any breaks.
Mar 31, 2009 | 1994 Ford Econoline
LG Washing Machine Model # WM1832CW, Error LE shows up
Trouble shooting steps for LE error on WM1832CW:
Nov 11, 2008 | LG WM-1832C Front Load Washer
La Crosse Technology La Crosse C86234 Wireless Weather Station Logo
1,188 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
ka4iup
ka4iup
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
