replacement-batter...This is a replacement compatible with a Nokia Mobile Phone Battery; Volts: 3.7V (3.7 Volts); Capacity: 900mAh (0.9Ah); Type: Li-ion; Color: Black ...$28.79 · ‎In stock
Sounds like the thermostat needs to be replaced adjusted or the probe to the thermostat is covered in scale, and it cannot read the temp correctly. Remove top panel and check probe, if fine no buildup, follow probe line to thermostat and set to a lower setting, if same problem replace thermostat.
This Danby unit should not do that. Get in touch with the company that sold it to you, they should replace the thermostat module with it's thermistor and this will be resolved. IF they give you ANY hassles, use the following website to contact Danby directly, they WILL correct this for you. In most states, you must start with the dealer.
Here's the site:
https://www.danby.com/en-us/support/
1. log into the router user 192.168.0.1 2. click the "home tab" then the "wireless" button on right will bring up the screen to enter your security information. 3. enter key desired key ( write it down and save to a safe place) 4. click "enable" at the top of page 5.click apply after all information is entered I hope this helps. Have a great day!
You can define a new WEP key by entering into your router's configuration (usually http:192.168.1.1) and then go to "Setup" and "Wireless". Here you can define a new WEP key.
