Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
What is "shift not on"?
'93 Mazda Protege (automatic shift) shifts from 1st to 3rd, then thats it. The RPM goes 3500 and up when I drive over 45 mph. I had to stay under 65mph driving across country recently. FYI...ju
Likely a gearbox issue.
Check condition of gearbox oil. If dark red or brownish in colour, then replace oil. Remove gearbox sump and replace oil filter. When replacing filter look for metal particles in oil
Retry.
If no success, or if finding large degree of chaff in gearbox sump, then likely a gearbox failure.
Oct 29, 2012 | 1993 Mazda Protege
Trans does not shift
I rebuilt my transfer case and as far as getting the transmission to work properly you have to adjust your linkage/cable to be almost perfect. Try adjusting that and let us know what happens.
Jun 11, 2012 | 1998 Dodge Durango
I recently had a used automatic transmission installed on a 2006 Nissan Sentra (1.8L) and it cost me $1,400. The problem I am having now is when I shift from "Park" to "Reverse" the car...
is the fluid level full and if this problem wasn`t there before the tranny was changed but was there after then the problem is the transmission.i have not come across a motor causing a no shift to drive or reverse ever.as long as the motor is running properly it won`t cause this.when you move the shifter from either to park then back your moving the internal shift components and shift valves by allowing fluid to move in the proper path to allow shifting into reverse and drive.there may be a stuck or worn valve in the valve body.
May 09, 2011 | 2006 Nissan Sentra
1999 3500 dodge 4x4 dually, 47re Tranny. problem existed before and after having my Tranny rebuilt. tried 4 new valve bodies even a new BD VALVE BODY. Truck starts out in 2nd gear when put into...
the transmittion keeps shifting in & out of gear between 45 & 50 mph it shifts to a higher gear then a lower then higher then lower till I get above 50 mph whats the problem & how to fix it
May 03, 2011 | 1999 Dodge Ram
The @ symbol is on the wrong key it is on " key ,
Hold down the ALT(ernate) GR(aphic) key (to the right of the SPACE BAR).
Hold down the SHIFT key.
Press the '@' key.
Release the '@' key.
Release the SHIFT key.
Release the ALT GR key.
Feb 26, 2011 | Acer NSK8458AN Keyboard
Some buttons don't always work: the "D", shift and
Try repositioning the wireless adapter or replacing the batteries. If neither work, contact Microsoft about a replacement.
Feb 25, 2011 | Microsoft Wireless Desktop 3000 Keyboard
Shift+2 gives "; shift +3 gives pound symbol;
It sounds like your keymap is off.
Try this:
http://www.conversationexchange.com/resources/keyboard-language.php
Nov 28, 2010 | HP Computers & Internet
We have a 1998 chevy blazer and we had my brother in law test the computer with the OBD2 and it read code "PO785" what does it mean
shift solenoid malfunction
google "PO785" and you will find more out about it. I saw something about a 3-2 shift
May 10, 2009 | Chevrolet Blazer Cars & Trucks
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
64 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
