Question about VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD)
Verifone vx510 shift not on
Will not transmit...cannot enter password, reads "shift not on" when I press "1"
hellonnnewma
  • 26 Answers
SOURCE: How can I solve the problem **tamper** in Verifone Vx510?
Verifone has a built in safe-guard against tampering. There are certain things that can cause the new Vx Series of terminals to display this error - from someone actually tampering with the terminal, to a physical drop or jarring of the terminal.
I hate to be the bearer of bad news, but the ONLY way for a terminal to be unlocked when displaying "Tamper" is to send it into an authorized service center. I have many of these devices in the field for customers and have dealt with this issue a few times - unfortunately, that's the only way Verifone set it up for this error to be resolved.
Sorry for the bad news, but hope it helped!
Posted on Sep 05, 2009
Testimonial: "I suspected that. Anyway I appreciate your attention and your cooperation."
  • 3 Answers
SOURCE: Instruction manual for Verifone Vx510?
http://www.verifone.com/PDF/guides/23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
Posted on Feb 18, 2010
  • 7 Answers
SOURCE: verifone vx510 missing msam card
Eternet/internet model do not use the SIM card. Please advise what is the P/N on bot label and I will advise.
Posted on Sep 02, 2011
  • 113 Answers
SOURCE: I have two verifone vx510 cc machines. 1st) Need
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Posted on Mar 01, 2012
  • 113 Answers
SOURCE: I bought a verifone vx510 and it apparently has a password already on it. I have used your reset formula: At the sales screen hit F2 & F4 together password is 1 Alpha Alpha 66831. No help. All
hi try 23378463 this maybe work but if dint work the only solution to your problem is to send it to a repair shop you need to reset back to factory default and you can only do it with the virfone software i hope this work for you if you still have question call me @ 775-358-2922
Posted on Dec 04, 2012
Verifone vx520 tamper please enter pasword
if you have a tamper you may need to get it replaced, try this press enter key and if it takes you to a menu press set up, enter password, do you have the password? 1 alhpa alpha 66831 ( the alpha key is above the 2) then press more until you see date and time, change date and time see if this fixes tamper or press red x until you get antoher screen or press f2/f4 same time enter password and then clock change time if this does not work you need a new terminal
Jul 22, 2014 | VeriFone VX510
How do I unlock vx510?
By unlock is this for the keypad, if so press the number 8 and enter the password of 1 alpha alpha 66831 enter and then NO- this will unlock the keypad, if there is another lock please submit that question
May 12, 2014 | VeriFone VX510
Vx510 terminal says keyboard locked
this happens when the number 8 is pressed. to unlock press 8 enter password 1alpha alpha 66831 enter, then select no, this will unlock your keyboard.
Apr 20, 2014 | VeriFone VX510
How to unlock keyboard
default password is 1, Alpha, Alpha, 6, 6, 8, 3, 1, and then press Enter.
Nov 06, 2013 | VeriFone VX510
Reset memory on Verifone VX510 payment terminal
if you want to remove all the memory you can do that easily, if you want to allow for more memory room you can press F2 and F4 at the same time, enter the password 1alpha alpha 66831 enter and then select the purple key under the arrow pointing down. select memory functions, and it will ask if you want to clear the memory, do this in group 1
Aug 19, 2013 | VeriFone Omni VX-510 Credit Card Machine...
How do i reboot
To Reboot the Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
Aug 31, 2012 | VeriFone VX510
Change time
1. Begin on the main sales screen
2. Press the purple MORE key twice
3. Choose OTHER SET UP from the display screen
4. Type in your password if applicable
5. Press the purple MORE key until the display reads SET DATE/TIME
6. Choose SET DATE/TIME from the display screen
7. Type in the date mm/dd/yyyy
8. Type in the time HH:MM:SS in Military Time
9. Press ENTER
10. Press the red CANCEL key
Mar 11, 2012 | VeriFone VX510
My verifone vx510 is displaying the wrong date, how can I change it?
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Select CLOCK [F3].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time. Key in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.when finish Select Restart [F4].
Aug 22, 2011 | VeriFone VX510
May 31, 2011 | VeriFone VX510
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD) Logo
117 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
