Question about Honeywell Programmable Thermostat Heater
Blower stays on with new themostat
My old programmable thermostat got fried on Jan 1 with no stores openned. Managed to find a UPM THM303M thermostat.
We AC and gas furnace with blower. 4 wires coming out of thermo: red, green, white, black.
Prior thermo had red to R, green to G, white to W and I believe black to Y but not 100 % certain.
Installed same layout to new thermo but now blower stays on indefinitely when fan set to auto. When I switch the Cool / Heat switch to the off position, the blower will stop but I don't want the blower/fan on one the furnace stops.
Help!
  • jesterbryanc Jan 04, 2009
    Thanks, machtc1
    Old fried t-stat issue not related. Two prongs (wife) got pushed together on the t-stat itself melting a part of the circuit board.
    Don't notice wire touching on new t-stat install. Tried black on Y and circuit breaker at the panel tripped.
    Black is currently back on B on the new t-stat not on Y. All works but the fan/blower stays on indefinately. Green wire still in G.
    Will be re-tightening the wires around the screws just in case this is the problem.
    Also bought a different brand (Honeywell) on the off chance that the UPM is defective.
    We have a gas furnace and external AC. Red wire is tape marked RC. Can you identify which wire runs which function? This might help me figure out the right combination.
    Thanks for all whom contribute to helping out!
  • 61 Answers
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Posted on Jan 02, 2009
  • Matt McElhenny
    Matt McElhenny Jan 05, 2009
    Red R-24v ac from furnace(R) terminal board to T-stat Rh/Rc
    White W-24v from T-stat to furnace (W)termnal board(during call for heat)
    Green G-24v from T-stat to furnace(G) terminal board(during call for AC or FAN ON)
    Yellow Y-24v from T-stat to furnace (Y)terminal board or out door condensing unit/or both.
    The furnace will also have a C terminal (common)
    Look at the furnace circuit board and see what black is hooked up to.
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
Display very dim
Posted under UPM wall timer.
Timer model and brand and approx age are unknown.
Is this new installation?
Was display brighter before?
Most timers have 1 year limited warranty.
Buy another timer.
Add a comment.
http://waterheatertimer.org/UPM-timers-and-manuals.html
Sep 22, 2012 | UPM Programmable Wall Switch Timer
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
Friend left RCT100 timer programmed, it comes on the time programmed, but it goes off much earlier than it is supposed to. How can I correct this?
Most digital timer problems can be solved by resetting timer.
Open following link for possible instruction manual with troubleshoot steps
http://waterheatertimer.org/UPM-timers-and-manuals.html#Garrison
Check the following:
Program disable feature is not enabled.
Check 2 different sets of batteries: 1 set AA for transmitter, and 1 set button-cell batteries on back of timer
Choose between 4 different functions: programmable, photocell, countdown, or random
Using programmable mode: make sure there are no programming conflicts
Jul 20, 2011 | UPM Remote Control Timer Set
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
417 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
