Question about Apevia Lithium Ion Battery Pack 4400 mAh for Acer Aspire 1800, Acer Aspire 1800WLM, 1800WLMi, Acer Aspire 180 (L18650AS18) Notebooks
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
The problem seems to be that there is no power whatsoever going into the machine. I initially thought it was the power plug so I tested it on another machine and it worked fine, so I took the battery out and powered it off the main... And still nothing. Any ideas?
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Posted on Oct 24, 2012
  • Will Coe Oct 24, 2012
    Heya, yea I saw that elsewhere and I tried that and no luck : (
  • Edu Osigwe
    Edu Osigwe Jul 09, 2016
    My Acer aspire 5742g cannot power on the Ac adapter and the power cord is good,it does not bring light on LED indicator if you plugs the AC adaptor i tested the battery socket in the mother board its bringing light but the laptop cannot power on
  • 72 Answers
SOURCE: When power cable unplugs computer immediately shuts down (have replaced battery)
Sounds as if the power pin (inside the computer) is damaged. The part is under $ 10 but the labor is gonna be a hundred to two hundred bucks. You can, if you are careful, fix it yourself.
You can also get a JerkStopper cable retention device to hold the cable in the correct position until you get the pin fixed. The cable retention device is designed to keep you from damaging the pin by pulling on the power cord. In this case, it sounds like it's too late for that.
Posted on Jun 04, 2008
  • 7 Answers
SOURCE: Acer Aspire One hangs during boot and then powers off after 30sec
sounds to me like you need to restore your bios settings to default. if you can get into bios usually by pressing delete then it shouldnt be too hard. if that dont work the next easiest thing to do is to take out the battery that is inside the laptop somewhere on the motherboard! this will clear bios settings after about 2 or 3 mins of being out make sure the computer has no other power going to it when you take out battery
Posted on Feb 17, 2009
  • 400 Answers
SOURCE: No power acer aspire 5310
Sir,
It seems to me that your Processor of the Laptop has got effected to and unbalance current supply. As you know that replace processor would work i would suggest you to claim its waranty before replacing new processor.
Posted on Aug 31, 2009
javaswing
  • 86 Answers
SOURCE: inspiron 1318 will not start
You need to take out the battery and try to power on the laptop with out it in..If it works then the battery is poched. Maybe the power supply you bought is wrong one? Did you buy it from dell?
Posted on Feb 24, 2010
carloadrian
  • 571 Answers
SOURCE: Battery of my Acer Aspire 4810T does not work.
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
1.
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
CARLO
Posted on Apr 13, 2011
Testimonial: "Thanks a lot. It works with adapter without the battery. But how can I know that it is the battery and not the motherboard that causes the problem?"
Acer aspire 5736z-4460 won't turn on
tried to remove the battery and then re attached, turn on the pc laptop check if it works.
Aug 03, 2012 | Acer Aspire 5736z 4460 Laptop
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
I have a Acer Aspire 7736ZG that won't boot anymore
Hello, on ACER 7736zg motherboard, the mosfet U58 of type si4812BDY fails very often, which causes the symptoms you describe. Tutorials are available on youtube for changing this chip yourself (<1$)
JP
Apr 10, 2012 | Apevia Computers & Internet
I have a Acer Aspire 5050-3371 Notebook. Before, I had a problem with it's battery and plug, so I disassembled it and found my DC input battery plug broken. I replaced the DC converter, and assembled...
Sometimes when the charger connector breaks, it shorts out the charging module on the motherboard, blowing it. It can also blow the external power supply.
If you can find someone else with a similar power supply, try using it. If that doesn't work, you've got bigger issues.
Jun 25, 2011 | Acer Aspire 5050-3371 Notebook
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
I have acer aspire 4551 where if I press the power button on the screen will not turn on, only power LED that lights up while the other led is not lit. I've tried to do the bios update by pressing the...
JUST REMOVE THE BATTERY FROM THE LAPTOP & ALSO THE CHARGER. LEAVE FOR 5 MINUTES THEN REINSERT THE BATTERY AND THEN CHARGER. NOW TRY TO START IT . SHOULD WORK. ELSE PLS REPLY
May 15, 2011 | Acer Aspire 4551 Notebook
Chkdsk hangs at 4% in step 1
You may turn off the laptop, remove the cables and battery. And then press and hold power button for 8 secs. Reinsert back the cables and battery then turn on the laptop. Check if chkdsk still hangs at 4%, this might be a hard disk issue. You may reseat the Hard drive by turning the equipment off, remove cables and battery, remove the screws underneath the 4 corners of the laptop, and then remove the Harddrive. You may reinsert it back and follow the sequence in descending manner. If all else fails, you may call Acer for repair...
Aug 01, 2010 | Acer Aspire One PC Notebook
Apevia Lithium Ion Battery Pack 4400 mAh for Acer Aspire 1800, Acer Aspire 1800WLM, 1800WLMi, Acer Aspire 180 (L18650AS18) Notebooks Logo
565 people viewed this question
Top Apevia Computers & Internet Experts
Paul Carew
Mohammed Ebrahim M
Mohammed Ebrahim M
Bill Boyd
Are you an Apevia Computer and Internet Expert? Answer questions, earn points and help others
