Question about Technics Audio Players & Recorders
Turntable is playing quiet
Plugged in Technics SL-J110R and the volume was very low , even at full volume on my amp the output was quiet. tested everything else its definitely something with the turntable. wasnt supplied with 'remote control cord' mentioned in the manual as i recieved it second hand.
    Champion:
  • Technics Expert
  • 271 Answers
Hi, if your not plugged into your amp via a dedicated phiono input, Ie CD or Aux then you need a preamp to boost the line levels. Cheers john. Styluscity
Posted on Nov 28, 2013
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
djproaudio
  • 515 Answers
SOURCE: Technics SL-1200MK2 Turntable i need to replace the on off switch on a mk2 technics 1200 any
The part is located HERE - but you will have to take apart your turntable from the bottom in order to replace it. It's not very hard, but if your not mechanically inclined, I would not suggest doing it, as you could cause more damage.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Posted on Nov 09, 2008
bob_computer
  • 3153 Answers
SOURCE: i PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE.
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Posted on Oct 02, 2009
Testimonial: "VERY FAST RESPONSE. THANKS"
lesliemurphy
  • 69 Answers
SOURCE: technics sl-b303
Try this company for help?
service<remove>@turntableneedles.com
they have a help line and may be able to assist you?
Note; take the <remove> bit from the link to email them?
Posted on Oct 20, 2009
I have a technics CD player with volume problems
Any cd player will only have one level output, i think you may have it plugged into the "phono" connection on your amp, which is different for turntables, please recheck.
Feb 28, 2015 | Technics Audio Players & Recorders
Tip
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."
Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
on Nov 05, 2011 | Technics SA-DA8 Receiver
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
Hello. I've tried a couple of amps now, and I still seem to be getting a very quiet volume output, even when the levels are high. I'm also getting no lows through the sub.
Hello,the first thing that comes to mind may be obvious but i have to state that the unit must be plugged into a phono jack only.These are scarce now but are required because the turntable needs extra amplification that standard inputs dont provide.
Jan 10, 2011 | Technics SL-1210 Turntable
Does my turntable need a new cartridge? I have a Technics SL DD22 which hasn't been used in a while. I hooked it up to a Bose receiver which works fine (hooked up an i pod to it before) & it plays...
The output from any regular turntable is far too low for most amplifiers to handle. You need to either run the output through a pre-amplifier first to bring the signal up to line output levels suitable for most recording devices and amplifiers or run it into an integrated amplifier which includes the pre-amp stage.
If your Bose receiver specifically includes a turntable input then it has a pre-amp built in, but as so few folks use turntables any more very few devices have the correct input. Pre-amps are still easy to obtain and can be very cheap, but cheap ones produce a noisy and unpleasant output which is magnified by the amplifier. If ever there's a choice to be made, spend the money on the pre-amp and go budget on the main amp.
I hope that I've saved you wasting money on something you didn't need. Please take a moment to rate my free answer.
Sep 24, 2010 | American Audio Vinyl 101 Direct-Drive...
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Pl 200 very low volume and where to hook up ground wire
Use the "mic" input on the amp. This unit does not have a "pre-amp"
It has a high-impedence output.
If your amp has a "pre-amp" input, plug it in there.
"mic" = microphone.
Sep 21, 2009 | Technics SL-1210 Turntable
Low volume after refitting belt on Technics SL-BS22B turnrable
check also the wire connections on the pickup head, don't forget to check the connections for the same wires inside the turntable, see if you have a bad solder contact to the output terminals, also check the terminals themselves for any dirt/oxydation (i assume they are RCA's, and they DO loose contact if you plug them in and out a lot). Also check RCA's at the amp end.
good luck
3rq8 (Triarcuate)
Jul 13, 2009 | Panasonic Technics SL-BD22D Turntable
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
317 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
