Question about Motorola MC9190-GST
Repeat character without pressing key
When you click a button, the keypade types multiple of that character when only clicked once.
5 Suggested Answers
SOURCE: Keypad
check tour keybord conector and cable.It will be work fine.
Posted on Apr 30, 2008
  • 5 Answers
SOURCE: razr keypad
its a simple problem and i dnt tink u will b able to do it.the main bord is connected 2 da key pad wichs also conects to da lcd.so basicly ur ribon is damaged.it cost about 150rand to repair.
Posted on Jul 28, 2008
  • 240 Answers
SOURCE: How to turn off the sound the keypads make?
In your tools or setup there will be an option for keypad tones on or off. Set them to off.If you have the manual it will be in there but otherwise look in phone setup.
Posted on Jun 13, 2009
  • 168 Answers
SOURCE: I have a Motorola Razor V3 mobile. Currently I m
software corruptd.. take it to moto service center and re-install ur software
Posted on Apr 13, 2010
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How do I turn off the blue keys on my acer keyboard? I do not have a fn key
    Solution 1 - Permanent OFF (windows 7)
    Go to Start menu > Devices and Printers
    Right click on HP Wireless Keyboard and Mouse Kit (yours may have slightly different name)
    Left click on Region and Language
    Left click on Change Keyboards button
    Under General tab go to > Default Input Language section > select English (Canada)-US
    Under General tab, now go to > Installed Services section > Keyboard heading > click on item for Canadian French then click the Remove button on the right,
    Repeat step 6 to remove line item Canadian Multilingual Standard
    Click Apply button at the bottom of window, then click OK button to get out of the window, click OK to get out of final window
    Close your Devices and Printers window and you are done FOREVER with the unwanted characters! :smileyhappy:
    Solution 2 - Temporary toggle between special/normal characters
    If it's like mine, the default keyboard setting requires you to do the following:
    press hold left ctrl+shift, then tap right shift key, this should toggle between the special characters and back to the normal characters when steps are repeated.
    Mar 17, 2015 | Acer Computers & Internet
    How do I type accents on a laptop without a secondary numeric keypad?
    Type character map in your windows search box and select the font you require. You may need to download the windows language pack for each language you use.
    Oct 26, 2014 | Compaq Computers & Internet
    How to fix sticky keys
    You must increase the leadtime before Windows considers your keeping a key pressed down means you want to repeat it.
    Open Keyboard Properties by clicking the Start button , and then clicking Control Panel. In the search box, type keyboard, and then click Keyboard.
    Under Character repeat, move the Repeat delay slider to the right to increase how long you must hold down a key before the keyboard character repeats, and then click OK.
    Jul 24, 2014 | HP Pavilion Computers & Internet
    Keyboard
    Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
    Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
    Feb 04, 2013 | Vizio Silver 15.6" Thin Light CT15-A2...
    Keyboard typing multiple letters/ numbers when pressing certain keys.
    Feb 03, 2013 | Computers & Internet
    My keyboard typing multiple letters
    Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard\'s repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
    If fails
    Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean
    If you are still feeling industrious, next you can tackle cleaning your mouse Of course, if cleaning your keyboard seems a truly undesirable task, you can always buy one for around $20.
    Hope this helps.
    Dec 31, 2012 | HP Computers & Internet
    How do you allocate an action to a button on the keypad.
    Hi to program your soft keys either follow the instruction or click on the link that I have posted, the video shows the newer handsets but these are very similar to your 12 button handset, ther are 60+ training clips at http://abbeytelecom.com
    Press the transfer button followed by 200
    Enter 1234
    Press 1 to 'ENABLE'
    Press the speaker key
    Now press 722 followed by the extension number of the handset.
    Type in the number of the button you wish to change.
    If it is button 3 then type 03, if it is button 11 type 11 etc.
    Once you have done this the cursor will move to the right hand side of the screen.
    Next press the letter D on the keypad followed by plus on the volume until it says DS.
    When it says DS press the 3rd grey key beneath the screen followed by the extension number. EG DS255.
    Once you have done this press the 3rd grey key beneath the screen to save.
    Mar 15, 2011 | Samsung Phone PDCSLCD12B
    When i press a character key from kayboard it displays digits
    The RIGHT side of the keyboard has multiple labels on each key -- alphabetic and numeric.
    Press the KEYPAD LOCK key to use the "keypad" layout.
    Press the KEYPAD LOCK key again to use the "alphabetic" layout.
    Nov 12, 2010 | Sony Computers & Internet
    SHIFT KEYS NOT WORKING PROPERLY
    Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
    If you have problem, let me know.
    Good luck.
    Thanks for using FixYa.
    Jul 27, 2010 | Acer TravelMate 2480 Notebook
    Motorola MC9190-GST Logo
    240 people viewed this question
    Top Motorola Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
