Question about NA LG E2742V 27-Inch Widescreen 1080p LED LCD Monitor with HDMI Input
I turn my monitor on E2742 and it says it is power saving mode. how do i get i off power save. it just happenen all of a sudden
Brand new out of the box. connected to my laptop need to access both screens
D-sub power saving mode
Look at the connectors on your monitor. Make sure they are plugged in firmly and the vga-cable is screwed on. Also look at the other end of the cables - same thing there!
Mar 14, 2014 | Velocity Micro Edge Z55 Core i7-2700K,...
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
Brand New LG Computer Monitor Flickers/Goes Into Power Save Mode
well right click on your desktop and goto properties and then goto screen saver and then goto power and then on the monitor setting goto never.
Sep 20, 2009 | LG Flatron L2320A 23" LCD Monitor
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Monitor flashes POWER SAVING MODE.. monitor dosnt turn on
A quick Google tells me this is a VGA analog interface monitor. Have you another monitor to test with, to see if the problem is the PC or the monitor. If another monitor works (esp. a CRT) your L1730s may still be fine. Set the refresh rate of the graphics adapter to 60HZ. then test your LCD again. Some monitors just blank the screen when they get a refresh rate they cannot handle. p.d.
Jan 14, 2007 | LG L1730S 17" LCD Monitor
NA LG E2742V 27-Inch Widescreen 1080p LED LCD Monitor with HDMI Input Logo
78 people viewed this question
Top NA Computers & Internet Experts
ray gallant
Tom Chichester
Are you a NA Computer and Internet Expert? Answer questions, earn points and help others
