Question about E-Machines eMachines Desktop PC
Hi... When I push the power button on my HP Desktop, just the amber light in the button comes on....nothing else. No noises (hard drive spinning-up, fan, etc)...nothing.
    President:
  • 1,179 Answers
The amber light is signifying an error. Most common are the power supply, video card, or RAM. Worst case is motherboard has went bad. Try reseating the RAM without installing the video card, if it boots then it's the video card. Replace the bad part & you should be up & running again. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 02, 2009
HP TouchSmart IQ526 all-in-one desktop will not turn on. The power button light is solid amber. Windows 10, version 1703, 8GB RAM.
it needs service (circa 2008 pc , as old as) carbon14 dated.
no all-in-one is easy to work on, cute to own hard to fix.
not as bad as laptop,
its non standard parts inside but the HDD.
so hard to service, as all things custom like this.
try a new power pack, if that fails. it needs a tech to fix it.
we check power first, in the world of electroncs Power is first.
the amber light is a warning, covered in the manual.
tells you getting started guide, "sleep mode"
hp has bad coverage on these, cheap , pc.
the servicing guide, is like useless, (how to add memory ) or.
no true book like they top tier do. (famous for) like elite books. or XM series , desktops
1: do the long reset yet, in the manual>
power off push power for say 30 seconds.?AC power pack pulled. (
pray?)
2: that button is named power /sleep too. so take it out of sleep mode. best is kill all sleep modes in control panel+power
until such times as it can work and not mess up, means OS freshloaded, it does.
the guide is here, see sleep words.
http://h10032.www1.hp.com/ctg/Manual/c01607512
  • does the CD eject button work, page 24?
  • does the fan inside spin, and blow. (heard and feel blow)?
  • does the HDD inside spin and make sounds,?
  • are there LED inside on the mobo that glow? if present is near the power jack DC (from power pack line) some have it others not.
  • is the fan inside packed in lint, as all seem do be this old.?
full support here
https://support.hp.com/us-en/product/hp-touchsmart-iq520-desktop-pc-series/3849079/model/3875697/manuals
Sep 30, 2017 | HP Computers & Internet
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Dell demension 4600c power light ok, hard drive light not on
sounds like hard drive dead or your boot files corrupted and your hard drive has no input power. could be power unit weak or your hard drive could have died..they do wear out.
do you hear any fans spinning? there are fans to keep your pc cool. one big one for chasis and one small on over processor chip(heatsink). if the smaller fan(especially) does not spin then PC will not boot because chip will heat up and break if no fan. system will protect itself from this by not starting. open chasis and check if small fan is working. if not this is cheap fix. if it spins then hard drive or graphics card may be bad, which gets more expensive. shop will charge average of $75 dollars to analyze-just to tell you what is wrong, not to fix it.
Aug 27, 2012 | Dell Dimension 4600 PC Desktop
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
I have a dell 3000 desktop when i hit the power button the little amber light comes on but not the geenlight, no fans or nothing works how can this be fixed
test all leads from motherboard to hard drive make sure connections are dust free and secure if its a 40pin ide it will be the first to fail
make sure the ram modules and cmos battery are securley seated with no dust in there sockets sme motherboards cmos batteries are soldered in
hope this helps you
Nov 14, 2011 | Dell Dimension 3000 PC Desktop
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
Dell XPS 200
Is the amber light blinking? Indicates PS not operating within specs. You can look at replacing the PS (~$79-99). GL
Aug 09, 2008 | Dell XPS 200 PC Desktop
E-Machines eMachines Desktop PC Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
