Question about Lexmark X6650 4-In-One Wireless InkJet Printer
I have put al new ink and it keeps saying im low or all out, i can not print anything but black and white
  • Official Brand Answer
  • 3,344 Answers
Make sure that you're using genuine Lexmark cartridges. If you are, unplug the power adapter of the printer and plug it back in after 20 seconds.
If it doesn't help, reset your printer back to its factory settings:
1Turn off the printer. NOTE: Make sure the printer is not in Power Saver mode. Press and hold I have put al new  ink and it keeps saying im low  - pattlnk_732009_107-on.png for two seconds to turn off the printer. If you have set the Power Saver timeout in the Setup menu, press and hold pattlnk_732009_107-on.pngaccording to the time you set in the menu. 2From the printer conI have put al new ink and it keeps saying im low - pattlnk_732009_108-green.pngimg src="http://i.fixya.net/uploads/images/I have put al new ink and it keeps saying im low - pattlnk_732009_109-x.png.png" alt="pattlnk_732009_108-green.png" class="h_mi" />anI have put al new ink and it keeps saying im low - pattlnk_732009_107-on.pnga.net/uploads/images/pattlnk_732009_109-x.png" alt="pattlnk_732009_109-x.png" class="h_mi" /> , and then press pattlnk_732009_107-on.png to turn
Posted on Nov 02, 2012
SOURCE: compatable black ink cartridge
Is the print out normal? If the print out is normal you just need to reset the software to know that you have a new cartridge.
If you open the printer cover, remove and then reinsert the cartridge you should have a message on your display asking you to align the cartridge. When you do this it will reset your ink levels.
If you are using a brand new Lexmark cartridge this should work find. If you are using a refilled cartridge then you will still see the cartridge as they are not supported on Lexmark products.
Thanks
Catherine
Posted on Sep 15, 2008
SOURCE: computer says there is no ink cartridge
OK guys, I don't know if this will work for you but it worked for me. Here it is:
  1. Uninstall all Lexmark software from Add/Remove Programs in Control Panel.
  2. Reboot the computer as suggested by the uninstall software
  3. Start the ALL-In-One Installer
Now, the first thing the installer does is load the drivers to your hard drive.
4. When the driver is installed it will ask you what ink cartridges you have. Tell it which ones you have and say they are both brand new (even if one is empty or not new). If it asks you to align the printer or print a test page, say no!
After this is complete, the installer will begin to put in the other software (i.e. fax and scan). It will pause and ask you to click next, but do not do this.
5. Press Ctrl+Alt+Delete, select the installer task and click end task to stop the installation process.
6. When you print for the first time, it may ask you what cartridges you have installed again. Just select the cartridges you have installed select the option from the drop-down boxes that say that both cartridges are new.
Hope it helps since it worked for me. Good Luck
Posted on Oct 20, 2008
  • 81 Answers
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Posted on Jan 03, 2009
vegakitten20
  • 685 Answers
SOURCE: refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Posted on Jan 08, 2009
Ajkill
  • 2035 Answers
SOURCE: lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 31, 2009
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
Keeps on saying cannot detect ink
if your Brother's printer is anything like mine, it won't print in any color (or black/white) if any one ink cartridge is empty. I just put any color cartridge I had in the empty slot to force it to print black and white.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Brother MFC 6490CW InkJet Printer
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can the printer still print on low ink on colors? It wont let me print anything, even black and white. On windows 7.. any problems there? It says that the printer is printing the page. But the Cyan is low...
It will print with no ink it will just be patchy.
It is also best to not let them run out of ink as they dry up in the print nozzle a pain to get working again and uses a lot of ink as you need to do several head cleans.
You may need to turn it of at the power point then after 3 minutes turn it back on again.
Also reboot your computer it may have not have started properly.
This should reset it.
Feb 07, 2018 | Epson Stylus Photo R200 InkJet Printer
Printer is not printing after putting in new ink
hi from brisbane !!
your Canon printer is detecting low ink in the cartridge and stops the feed of ink .
i have had the same problem and have only refill the cartridge and its away again .
the cartridges have a few contacts on the back and sometimes by applying a magnent to those contacts , it erases the memory and start printing again .
try that and let me know how you go .
Sep 30, 2009 | Canon BubleJet i965 InkJet Printer
HP C4500 ink consumption
Dear Sir,
Now a days all HP ink catridges available at low price that means ink quantity is also low.So if you print heavy coloured pages it will deffinately consumes more ink.So print in gray scale or black and white consumes low ink. Compare to gray scale,black and white printing consumes very low ink. So print in black and white is the better choice.
good luck
Aug 08, 2009 | Office Equipment & Supplies
Cant print in black and white when out of a color.
disregaurd any prior solutions in cleaning any contacts. that model doesnt have an electrical contact to clean. there are little magnets inside each color and black cartrige that work off a float mechanisim inside each one. when the levels get low the magnet indicates to the printer it is empty. unfortunately for you this stylis model as with all brother model printers wont work even if the color your setting up in the properties or settings feature are set to black and the black is full. its the companies way of forcing you into buying new ink. be aware though that my brother catriges cost 78.00 for the 3 color and one black set. i found these cartriges online through ebay but with one more additional black cartrige for a total of 5 not for ,for a total cost of 13.11 with free shipping. sounds too good to be true but for 13.00 it was worth a try. i have now purchased several 5 packs from them and couldnt be happiere.
Jul 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Printing when ink is low
The machine requires all color in order to print anything, even just black and white copies. You need to install a new cyan ink before it will print.
Feb 10, 2009 | Brother MultiFunction Center MFC-440CN...
Refill ink not printing Lexmark x4550
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
